Emission warning light
While on a run tonight the emission control warning light has come on, anyone know the usual cause for this. I've ordered Vagcom so will check codes early next week, but is there any "common" issues?
Mark
Mark
Daytona Grey, black wheels , Miltek, sports cats.
Re: Emission warning light
Hi Mark,
You could surmise till the cows come home, wait for the VCD kit or if you can touch base with a member locally?
Where about's are you?
Good luck
Good luck
RS4 B7 Avant,2007
Chorley in Lancashire. Yeah should be here Monday. It's had a slight mis while idling for a while. So I suspect a coilpack.
Monday spot on, it will be the best bit of kit you have ever owned
Mines just had an O2 sensor changed which I found using VCD's, running sweet now
Good luck and report back on your findings
RS4 B7 Avant,2007
Mine came on last year and turned out to be a lambda sensor. I'm also from chorley lancashire and I've only ever seen one other b7 it was a Daytona grey saloon.
yeah mines a Daytona grey saloon, black wheels.
- PetrolDave
+1R1RS4 wrote:You could surmise till the cows come home, wait for the VCDS kit
There are literally dozens of reasons for the light to come on, without VCDS to see the actual fault codes you'll be P155ing in the wind trying to guess what the cause is.
Mine is the same.mark r wrote:yeah mines a Daytona grey saloon, black wheels.
I may have seen you one morning pretty early about 6:30 on the a6 near shaw hill.
yeah oxygen sensor, post cat bank 2.
need to order one now and find out which is bank 2 lol
Bank 2 is the passenger side, stealers would have charged me about £255 with vat but was covered on my warranty.
RS4 B7 Avant,2007
Forgot to say, the sensor is £90 at the stealers, found on EBay for about £53 when I was looking, was going to change myself but could not get mine out, stealers used heat, not so bad on a ramp, but with SS+ could not get it high enough pc the ground
RS4 B7 Avant,2007
cheers, will order a bosch one from somewhere, i always find them the best
Users browsing this forum: No registered users and 388 guests
