Wanted: c5 rs6 abs ecu
Keaney
Post by Keaney » Fri Jun 13, 2014 10:40 am
Does anyone have a rs6 abs ecu for sale or one I can borrow?
Had a constant abs sensor issue and so far have tried:
New sensor
New wiring
Brake switch
Abs ecu sent to bba reman and no fault
I can only come to the conclusion that it must be the ecu and question the bba service
A7 3.0T - Pretty Std at the moment... in warranty
VW Caddy 2k 1.9 TDI - Std
Has beens:
C5 RS6 Avant - Wagbo'd, PSS9, MiIltek Res, MRC Stage 2, ACE Torque Converter, 551ps 815nm | 00 B6 A4 2.5TDI | 01 Nissan R34 GTR V-Spec (UK) | 93 Toyota MR2 GT | 95 Mitsubishi FTO | BMW 318is | Vauxhall Corsa 1.4 16v SRI | Vauxhall Nova 1.3SR Chavtastic
saulcupra
Re: Wanted: c5 rs6 abs ecu
Post by saulcupra » Fri Jun 13, 2014 12:31 pm
whats the fault code pal?
could be related to the F125 switch on the box (throws as an abs code)
saulcupra
Post by saulcupra » Fri Jun 13, 2014 12:32 pm
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 AD
1 Fault Found:
01119 - Gear Recognition Signal
35-00 - -
Keaney
Post by Keaney » Fri Jun 13, 2014 1:51 pm
It's
00287 - abs wheel speed sensor; rear right (g44)
30-10 open or short to plus - intermittent
Has beens:
