Just when everything it's fixed then I get this who has had
Jamiestanton
Post by Jamiestanton » Sun Apr 20, 2014 11:22 am
Car was running perfect after new clutch fitted some little problems but there sorted now
Then I get this
Mad noise from the clutch pedal sounds like a ratchet noise as I let off not doing it on stand still just when moving as you release the pedal now and again hope this is something on the back of the pedal
Has any one had this happen to there car
Apart from that everything else is good for now
2006 black audi rs4 b7 mrc stage 2 stage 2 manifold de cats miltek coil overs light weight flywheel black optics 445bhp 470nm
adsgreen
Re: Just when everything it's fixed then I get this who has
Post by adsgreen » Sun Apr 20, 2014 12:04 pm
Did you have flywheel replaced at the same time?
Jamiestanton
Post by Jamiestanton » Sun Apr 20, 2014 12:45 pm
Yes I changed fly ,slave,master,spring on pedal ,pipe from slave
First few days fine then yestoday started making this mad noise like plastic clicking it's strange maybe something on the back of the pedal I have missed
Only doing it when running
I wonder if there is air in the system
Or the it's adjusting it's self
Covkiller
Post by Covkiller » Tue Apr 29, 2014 8:17 pm
If it didn't make that noise before you paid £3k for your repair go back and raise merry hell :audibash:
cherub72
Post by cherub72 » Tue Apr 29, 2014 9:52 pm
I had this after my clutch was done, it was the big return spring behind the pedal. Seems when the clutch was out the pedal moved and the spring come off the mountings. Not an expensive part but it came as a shock when it popped out and smacked me in the shin
RS4 Cabriolet - Phantom Black with Exclusive interior
Jamiestanton
Post by Jamiestanton » Tue Apr 29, 2014 11:32 pm
Covkiller wrote:If it didn't make that noise before you paid £3k for your repair go back and raise merry hell :audibash:
£3k where you been taking your audi
Mr Footlong
Post by Mr Footlong » Wed Apr 30, 2014 7:51 am
So how much did your swap cost then??
Current:
Gone:
Covkiller
Post by Covkiller » Wed Apr 30, 2014 7:52 am
Oh yes, on mine a couple of months ago
Fly wheel, clutch and spring, slave & master, pipe from slave and brake fluid full flush.
£3k Audi Cov
Mind you it works now
Jamiestanton
Post by Jamiestanton » Sun May 18, 2014 6:16 pm
Mr Footlong wrote:So how much did your swap cost then??
Just over £1000
Jamiestanton
Post by Jamiestanton » Sun May 18, 2014 6:18 pm
It was the blue clutch pedal switch making the noise must have been faulty one took it back to tps they swapped it for me I fitted it and every think if cool now
Users browsing this forum: No registered users and 195 guests
