Timed acceleration runs
- Graeme4130
I know it's not exactly a vbox, but this is the last launch timing I had in my RS4
The app's called dynolicious and when I compared it to vbox data once, it wasn't too far out Temp was 14deg and the road was dry
I'll do the same in the rs5 I have on loan if I get a chance
Anyone else have any data ?
Re: Timed acceleration runs
Only similar data I've seen so far is the Chris Harris rs4 vs s4 test. Impressive Graeme
That is quick!! Maybe sakamino has some time slips- data
it's a lot more accurate than people give it credit for!
This was my best run in the RS3 prior to it having APR' stage 1 map:
B7 RS4 Cabriolet with custom Blueflame - Gone
Misano red RS3 running Stage 1 APR - Gone
Sepang B8 RS4 with buckets - Gone
Panther Black C7 RS6 - Current Daily
You can see where forced induction benefits the '3 compared to Graeme's time. I didn't think it would be so pronounced.
200KG extra weight?
Quattro drivetrain losses?
Naturally aspirated vs. Forced induction.
Both using launch control?
Level road?
Level road?
- Graeme4130
There's definitely a fair amount of variables in that comparison. However, I've come against a modded rs3 before in a straight line, and got smokedHYFR wrote:200KG extra weight?
Level road?
Did a few runs tonight. This was the best timing.
Launch control
27 Deg
Relatively flat surface
Dry surface
38/35 PSI tire pressure measured cold in the morning
Full tank of fuel
No passenger, only driver
Minimal luggage
Ignore the higher speed timing. I let off after hitting 180 because I had to turn off Stability control for executing the Launch Control and thought to take it easy.
Launch control
27 Deg
Dry surface
Full tank of fuel
Minimal luggage
One more thing, I am on Toyo T1A0 tires. Stock tires for the RS4 at this part of the world.
Good times!! I trust your driving a b8 yes?
Yup, can't wait to test her again with other bolt on parts. Nothing as serious as yours
What did it do stage 1?Macdaddy wrote:it's a lot more accurate than people give it credit for!
2011: 2.0T FL Octavia VRS
2010: 1.8T Octavia VRS
It was flat road, launch control.
It fairness it averaged out at 4.3 over 4 runs.
I've not managed to run yet since the map however others are quoting times of 3.3-3.6 mapped, i do know those on super bikes don't pull away from you at the lights
- Graeme4130
A fireblade will do 0-60 in 2.8 and 100 in 5.5, so to keep a superbike in view off the lights is veyron fastMacdaddy wrote:It was flat road, launch control.
1199Panigale
Almost as fast as a Panigale
Users browsing this forum: No registered users and 75 guests
