CEL P0491 /P0492
5.0 V10 50v biturbo - 571 bhp
993turbo
CEL P0491 /P0492
Post by 993turbo » Tue Mar 25, 2014 9:32 pm
Got the CEL today. P0491 / P0492. VCDS readout: SAI system insuffcient flow bank 1 / 2
any ideas?
Cheers.
:D
RS6 MTM C6 Avant (Daily Driver)
360 Modena (manual)
F430 Spider (F1)
+ 4 classic Porsches
C6NVS
Re: CEL P0491 /P0492
Post by C6NVS » Wed Mar 26, 2014 1:24 pm
This might help as a start:
http://www.audizine.com/forum/showthrea ... leshooting
Also, check the connectors into the airbox on both sides. These can sometimes split at the airbox connection and cause an air leak in the system, setting off the codes.
Daytona C6 RS6 Avant: Demand Engineering Exhaust (Downpipes custom to tip)
Soon to add: Hybrid Turbos; Uprated Gearbox; Marston Intercoolers; ECU / TCU mapping
993turbo
Post by 993turbo » Wed Mar 26, 2014 2:50 pm
Cheers, I did delete the codes, and they did not come back yet.... :audibash:
Will check the connectors etc.. Cheers for the link. :biggrin2:
360 Modena (manual)
F430 Spider (F1)
perthwaRS6
Post by perthwaRS6 » Wed Mar 26, 2014 6:11 pm
Hi 993turbo, :bigwave:
I had same SAI code- see pic 1.
Under warranty, engine pulled for SAI replacement, along with clean up of electrical connectors.- see pic 2.
From trolling Audizine, poor electrical connections are a significant cause of error codes.
After the warranty repair, Audi Diagnostic did not show any further error codes.
Strangely , the beast is running a lot stronger since the warranty work. Cant see why as SAI does not influence turbos/boost etc (?). Maybe some of the other "clean up " work listed improved performance?
Unfortunately, almost straight away now throwing up VCDS error codes again and have since owned the beast on bank 1 -p2261 Boost pressure control valve (N249) mechanical malfunction and bank- 2 p3084 -turbocharger bypass valve- mechanical malfunction.
Cannot understand why these two VCDS errors keep coming back again as no discernible decrease in performance feel of the beast. :? Possibly a very small boost leak?
Will have to learn how to run my VCDS real time data logger function while driving to see what is happening between called for boost and actual boost.
Off to Audi dealer for a scan to see if they can replicate the VCDS errors p2261 and p3084. They look for but seem to not be able to see these errors on their scans so cannot repair under warranty. :drink:
Just keep an eye on your scans for more SAI codes.
just my two cents worth.
cheers,
john
AUDI C6 RS6_Secondary air injection fault_P0491_02 VCDS scan.JPG (33.07 KiB) Viewed 2255 times
2009 RS6 sedan,5.0L FSI V10,phantom black,730bhp-98 octane,750bhp-104 octane,APR stage 1 map,MTM/Performance Friction 405mm front rotors,JCFabweld sports exhaust,MRC filters,Michelin PSS.
2011 Lamborghini Gallardo LP560-4 coupe,5.2L V10 TT UGR 800-1250whp, e-gear 6 speed,390 mm Alcon Racing front rotors, grey.
1969 E type Jaguar convertible with 5.2L 6 cylinder Rob Beere Racing engine,356 bhp-415 ft-lbs,midnight blue-old school but beautiful
Erwan35
Post by Erwan35 » Tue Jun 18, 2019 8:01 pm
So what seems to be the problem? I am having same codes. Please help. Audi rs6 c6
RS6 C6 SEDAN RHD VS_PERFORMANCE STAGE 1.5, 2ND CAT DELETE, MILTEK CATBACK, BMC DROP IN FILTERS. :blackrs4:
