C5 Gearbox problem
RS6Rottweiler
C5 Gearbox problem
Post by RS6Rottweiler » Thu Mar 13, 2014 2:08 pm
Hello all;
Looking for some advise or if anyone else has had the same problems I am experiencing with my C5 Gearbox? My car has been chipped and produces approximately 507bhp and as far as I am aware chipping also remapped the gearbox?
I started to experience problems about a year ago when I first start the car in the morning, when I select drive the car hardly moves similar to a slipping clutch, if I stop and restart the engine and select drive again everything is fine. I have no problems with reverse and usually the problem does not show its self again that day. However of late the problem is very intermittent, somedays I have no issues and other days it happens quite a lot. I also noticed last summer with all the good weather that we had that it never happened until the colder wet weather came back? As far as I am aware I am not experiencing any issues with hunting, gear change or anything else like that so I wondered if anyone else has experienced this problem and what was it diagnosed as and how was it repaired?
Star Performance look after my car and they think it could be a solenoid problem which I believe requires the removal of the gearbox to access the solenoids and they have told me that the only place in Scotland that does this is Mackies in Glasgow. Has anyone used Mackies and how did you find them?
Thanks in advance for any advise you can give me.
Re: C5 Gearbox problem
Post by Shoppinit » Thu Mar 13, 2014 2:38 pm
Probably fluid level / quality. Time for a gearbox service.
Also if you go to drive too soon after starting you can run into problems.
I've never heard of a solenoid failing. Sounds like grasping at straws to me. And the box doesn't need to be dropped to get at them. That's bollox.
Might be a valve body problem.
First scan your car for codes.
RS6Rottweiler
Post by RS6Rottweiler » Thu Mar 13, 2014 3:01 pm
Hi;
Thanks for responding, the gearbox was serviced about two years ago oil and filters changed so this could get rechecked and see if it makes a difference? I wasn't sure where the solenoids are hence why I have come onto here to get advice from more knowledgeable guys> I have to admit that it did appear strange that solenoids would be put inside a gearbox, they did clean up all the electrical contacts but this made no difference?
Not sure what you mean by valve body problem could you elaborate on this for me?
The main reason for trying to find out what is wrong is so that I can hopefully get an idea on whats wrong with the gearbox before I give a blank cheque to Mackie's or who ever will be carrying out the repair. It could be nothing or it could be something serious but apart from not going into drive when selected it appears okay, however, this fault resets if I start and stop the engine. I have noticed recently that it does jump into gear when this happens and when reset it doesn't, there doesn't appear to be any other issues that I have noticed, all other gear changes are smooth when driving slow or pushing the car hard?? Hoping I can get to the bottom of whats wrong as it would be good to get it resolved and hopefully it won't be too expensive, but I'm not holding my breath on that one?
grizz
Post by grizz » Thu Mar 13, 2014 4:19 pm
Do a diagnostic as it could just be the gearbox switch on the side of the box .
Unit 20
0151 3366888
RS6Rottweiler
Post by RS6Rottweiler » Thu Mar 13, 2014 7:04 pm
Thanks Grizz;
I will get Star performance to have another look and see what failure codes come up and mention what has been said, thanks for your help.
iaingbrown
Post by iaingbrown » Fri Mar 28, 2014 10:15 pm
I had recon. gearbox installed by Mackies about five years ago. No problems with them. Not cheap, I think circa £6k plus the old box.
The car was transformed: probably drove 10-15K with box on the way out. I've had one gearbox service from them since ( about £200?) not sure what they do apart from change the ATF tho'.
bilko1
Post by bilko1 » Sat Mar 29, 2014 12:18 pm
Shoppinit wrote:Probably fluid level / quality. Time for a gearbox service.
What problems are you talking about Shop? I've never had a problem yet but perhaps I'm too slow.
gingertoss
Post by gingertoss » Sat Mar 29, 2014 2:47 pm
Mackies service mine. Circa £300 for a fluid and filter change. They did say mine was a doddle as there are no cats in the way.
2003 RS6 Avant, non res Miltek, 3" catless dps, wagners, MRC air filters, 044 fuel pump, MRC custom remap, TCU remap, 566ps, 812nm, pss9 coilovers, hotchkis rollbars, Recaro CSs, 390mm front discs, hi-spec 4 pot rear calipers.
RS6Rottweiler
Post by RS6Rottweiler » Thu May 08, 2014 6:21 am
Hi, apologies for the long delay in getting the fault code information but got there in the end. I am told there is one gearbox fault code that has come up so would greatly appreciate any information / advise anyone can give me on the possible fault and solution to this problem?
Fault Code: 18243 Pressure Control Valve 5. P1835-35-10 Short to Plus Intermittent.
Anyone got any ideas what is causing this and what the solution is?
mik15
Post by mik15 » Thu May 08, 2014 6:31 am
i'd start by checking the TCU, some water might have got inside, check all the pins for corrosion, clean them and then put it back together, clear the code and see what happens...next would test the solenoids with the VCDS and see if all act as they should....
2004 RS6 by ABT, madly in love with it, RNS-E, ST coilovers, new TC, 19x9x29 RS4 B7 wheels, non-resonated Milltek w/blk tips, TBC....SOLD - but never to be forgotten!
2004 RS6 ebony schwarz, SE exhaust, 19'' rims - SOLD
'09 RS6 C6 - the great white - now, this means business!
Post by Shoppinit » Thu May 08, 2014 7:24 am
Sounds like changing that valve might be the place to start.
longman h
Post by longman h » Thu May 08, 2014 9:24 am
Right, after doing some research, I think you're going to need to replace the wiring harness that holds all the solenoids/valves to the mechatronics unit.
Funnily enough I've just ordered one of these to get rid of the transmission fluid temp sensor error I'm getting.
This is what the harness looks like once it's removed;
I'll try and find out the Audi part number and post it up.
Just for some info, this is a photo of the wiring harness in situ. The lead going to the top of the image is the temp sensor.
Hope this helps.
One thing I'm contemplating about doing is driving over to Dortmund and having the mechatronics unit completely refurbished by ZF themselves. It's quite cheap and from what I've read on other forums, it's solved all their trans' issues.
Have a read: http://www.bimmerboard.com/forums/posts/527361
:thumbs:
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
longman h
Post by longman h » Thu May 08, 2014 9:26 am
Ps. It may be slightly more expensive for us RS6 owners as they'll probably need to remove the engine first!!!! :audibash:
mik15
Post by mik15 » Thu May 08, 2014 9:45 am
if they're only doing the VB no need for engine removal...very interesting article and that BMW is also running a 5hp24...for cca350Eur is really cheap compared to what results you get...look for automatic GB parts here too: https://www.automaticchoice.com/
el_ringo
Post by el_ringo » Thu May 08, 2014 7:08 pm
Wouldnt a new valve body do the same as that service?
Daytona Grey (C5) RS6 saloon, but just a little better...
**** SOLD!!! :( ****
KW V3 suspension
390mm C6 Brakes
Hotchkis ARBs
Viper Tuning (537bhp 604lbft)
Unit 20 TCU remap
Milltek non-res exhaust and downpipes
100 cell sport cats
Aero wipers
Winter wheels
Wagner intercoolers
LED interior lights
Tesla Model S 85D
All the options with the exception of stupid air suspension
Tesla Model X 60D
Silly doors and all!
Users browsing this forum: Google [Bot] and 67 guests
