Odd engine trouble
Odd engine trouble
Post by Shoppinit » Fri Mar 07, 2014 10:27 am
Hello peeps.
Would appreciate a bit of help troubleshooting this off problem with odd symptoms but no obvious connection. Well, I can think of one, but I don't want to taint others' views.
So the symptoms are this:
1. No more one-touch start - you have to hold the start button in to keep it turning over
2. Revs don't come back down quickly after blipping throttle - results in jerky gear changes
3. Cruise control not engageable.
Anyone seen these symptoms together before?
CheeRS!
/edit: forgot to mention, I'm not with the car at the moment but will scan it ASAFP.
alex020869
Re: Odd engine trouble
Post by alex020869 » Fri Mar 07, 2014 10:32 am
Sounds like your clutch switch is faulty.
Cheap fix and only 10 mins work.
Alex
RS4 B7 Mugello Blue Saloon
rs4Mav
Post by rs4Mav » Fri Mar 07, 2014 11:03 am
Defiantly your clutch peddle switch, I had the same symptoms end of last year on mine.
New switch from Audi stealers £17, fitted myself in just under 15 minutes, job done.
Just make sure you don't push the plunger in on the new switch before fitting, as this will make it useless, if you do a search on here you will find full guide on how to install it.
Post by Shoppinit » Fri Mar 07, 2014 11:16 am
Ace. Thanks. I was thinking accelerator pedal issue, but clutch switch makes sense. Will a DTC be logged? I do like positive confirmation.
pandavet
Post by pandavet » Fri Mar 07, 2014 1:50 pm
Hi guys, thank you for your help. :beerchug:
The log shows effectively a clutch pedal switch default : 20€, 5 minutes... Well, 20€ for me, and 5' for Shoppinit... :biggrin3:
I can relax now.
JP
Frenchy lost among UK fans... ;)
Current : b7 RS4 Avant - Avus grey
Previous : 8p A3 2.0 TDI DSG (2004-2005), b6 A4 Avant 1.8T Quattro (2005-2007), b6 S4 Avant 4.2 (2007-2011)
PetrolDave
Post by PetrolDave » Fri Mar 07, 2014 6:13 pm
alex020869 wrote:Sounds like your clutch switch is faulty.
+1
Those are the 3 classic symptoms of the clutch switch having failed.
coffey555
Post by coffey555 » Fri Mar 07, 2014 7:42 pm
I did my one last week. Make sure you turn the new switch firmly fully clockwise when fitting (you will hear and feel an audible click when it is fully home) otherwise nothing will happen when you press the start button.
Misano Red RS4 B7 Avant
C17LJR
Post by C17LJR » Fri Mar 07, 2014 8:54 pm
I've just got the same symptoms, better get one ordered
2007 Daytona Grey RS 4 Avant
2013 Daytona Grey RS 4 Avant
pandavet
Post by pandavet » Sat Mar 08, 2014 7:53 am
@coffey555 : yep, the Audi tech told me the same. ;)
JP
Users browsing this forum: No registered users and 427 guests
