Pad wear.....
4.2 V8 32v FSI - 444 bhp
smudge
Pad wear.....
Post by smudge » Tue Feb 25, 2014 2:40 pm
Anyone got any ideas on expected pad wear (steel discs). I've just been advised by the dealer that my fronts are at 75% after 16k. :shock:
I'm really not that heavy footed, I'm almost always driving around central London (over 80% of that time is spent at low speed) or I'm on a motorway run to Berkshire. Pad wear can't be that heavy on them surely??
It's all torque talk.
Nickyboy
Re: Pad wear.....
Post by Nickyboy » Tue Feb 25, 2014 2:51 pm
You like to moan dont you. Sound like me.
2011: 2.0T FL Octavia VRS
2010: 1.8T Octavia VRS
smudge
Re: Pad wear.....
Post by smudge » Tue Feb 25, 2014 3:02 pm
:lol:
I'm having a bad week by the looks of things!! If I'm coming across as a grumpy old git, its because I am! :P
I guess a potential £1500 plus labour bill is a bit of a shock when all it went in for was some sticky tape for the rvm........ :shock:
Nickyboy
Re: Pad wear.....
Post by Nickyboy » Tue Feb 25, 2014 3:18 pm
:audibash:
Can't believe I'm still with Audi with all the issues I'va had.
doodlebug
Re: Pad wear.....
Post by doodlebug » Tue Feb 25, 2014 3:19 pm
Yep, disc and pad wear is quite high on this setup, that's why ceramics are good value.
eightfoot
Re: Pad wear.....
Post by eightfoot » Tue Feb 25, 2014 3:25 pm
smudge wrote:Anyone got any ideas on expected pad wear (steel discs). I've just been advised by the dealer that my fronts are at 75% after 16k. :shock:
you do like to worry dont you :bigblink: should have stuck the mirror on yourself,as for the brakes i would'nt worry till the wear light comes on it might last another 20000mls if you dont drive hard by then you might want to try something else :beerchug:
blueaudi
Re: Pad wear.....
Post by blueaudi » Tue Feb 25, 2014 3:27 pm
£1500 for a set of front pads? I would go to a reputable independent, ask them to confirm the state of the pads and get a quote. I had a similar experience a couple of years ago with a Porsche Centre somewhere near Birmingham, I happen to know a local independent and he confirmed that the pads had plenty of life left in them, when the time came to change I went to him for almost half the cost, warranty unaffected as they were genuine parts. I now use a Pork dealer somewhere near Leicester by the way.
2015 RS4 on the way
2014 SQ5
2011 Disco 4 HSE
2011 Mini One
smudge
Re: Pad wear.....
Post by smudge » Tue Feb 25, 2014 3:54 pm
[quote="blueaudi"]£1500 for a set of front pads? /quote]
Sorry, my bad... Front & rears, but they've included new discs in the quote as well from what I can see.
[quote="eightfoot"]you do like to worry dont you :bigblink: should have stuck the mirror on yourself,/quote] It's my old age...... as for the mirror, I tried myself, but failed, it's quite a heavy beast for blue tac.....
Regardless, I don't think that self fixing should be the solution here & Audi have confirmed (verbally) that there are some issues with early rvm mountings. :thumbs:
Graeme4130
Re: Pad wear.....
Post by Graeme4130 » Tue Feb 25, 2014 9:22 pm
My light went on at 16k miles for the fronts. I believe the wear indicator is 80%
Mine were changed under warranty though (along with discs and calipers) just after due to the squealing issue for upgraded versions, which the new ones are causing problems too, but that's another story altogether
