afew pics..
finally got the 20s on....
managed to get the new wheels fitted yesterday, 9x20 with 255 30 gy eagle f1s, .... after all the messing and spacer issues with the 10x20s just ended up going for the rotors, not touched the suspension yet but drives surprisinly well on standard set up.
afew pics..
afew pics..
2006 Sprint blue 20" rotors, revolution induction, nav, buckets, sunroof
2010 alpine white 320d m sport, I drive , nav, red leather
2008 Yamaha grizzly 700fi, camo, power steering, 27" executioners, warn winch, plg registered
Re: finally got the 20s on....
Looking good. What you thinking suspension wise?
2007 Daytona Grey RS 4 Avant
2013 Daytona Grey RS 4 Avant
CellDamage
not sure yet, my brother has coilovers on his rs4 and it has a very harsh ride, was thinking h&r springs keeping the drc system???C17LJR wrote:Looking good. What you thinking suspension wise?
its a quattro badge under the rs4..CellDamage wrote:What's that badge under your RS4 one?
quattro.CellDamage wrote:What's that badge under your RS4 one?
look good mate, im biased tho, rotors are popular now, but look ace imo
I've got H&R's on mine only problem is the fronts, the car sits too level.
The rear is perfect, with the tyre walls sitting about a quarter under the arches but there is still a gap up front.
It's far from reverse rake but I'm going to get the front springs modified by a company that make race suspension and springs in Sheffield, they just need about 10mm for it to sit perfect.
So if your a bit anal about your stance I don't think you'll be 100% with springs alone without modifying them.
maybe try the b5 spring perch mod drops the front by about 3/4 inch?, less hassle than getting the springs modified.jaysrs4 wrote:I've got H&R's on mine only problem is the fronts, the car sits too level.
- John Johnson
- 5th Gear
Coil springs 1989 ? Used them a lot a few others havejaysrs4 wrote:I've got H&R's on mine only problem is the fronts, the car sits too level.
Current toys in the garage
B7 avant in Daytona with ceramics and a few other goodies and lowwwww miles
Ur quattro. lago Blue
Ur quattro. Mars red
Rs1600i
Transit custom sportvan
http://youtu.be/FWBUl7oT9sA
Rs1600i
Ah please tell me more!!sar wrote:maybe try the b5 spring perch mod drops the front by about 3/4 inch?, less hassle than getting the springs modified.jaysrs4 wrote:I've got H&R's on mine only problem is the fronts, the car sits too level.
Thanks Sar for the heads up on this. Been doing some Audizine searching and looks like I'll be off down to Audi in the week!
Lower B5 front spring perches/plates - I assume the fools in parts will know what I'm talking about?!
Or you could go for the kw adjustable spring kit. This means you keep the DRC but can still set the ride height as you like it.
Obviously, i'm a fan of rotors too.
Just a update on my rs4... changed the headlights to clear.. fitted full leds inside and out off trupps.. much better( slight issue with the sidelight leds tho ) fitted led rear lights, Resonated valved Miltek catback, Revolution induction fitted, Rotors took off for winter. Rear tints done... a think thats it
Intake pic
Users browsing this forum: Google [Bot] and 82 guests
