Driving in Germany
Fatneck73
Driving in Germany
Post by Fatneck73 » Wed Jan 22, 2014 8:06 pm
Hello all
I'm trying to find out where is best to go for a drive. My C6 is itching to stretch its legs!
Am I right in believing that autobahns are 'by default, de restricted unless restricted'????
Anyone know a bahn that is DEFINITELY derestricted...I don't wanna get this wrong coz I'll be far more than 'just a little over the speed limit'!
Any advice / guidance?
iR8V10
Re: Driving in Germany
Post by iR8V10 » Wed Jan 22, 2014 8:43 pm
Just look for what is out National Speed Limit Sign.... That means unrestricted.
If numbers are displayed, there's a limit.... Simples.
Fatneck73
Post by Fatneck73 » Wed Jan 22, 2014 10:01 pm
Yeah, got that but they don't seem that common - when I went to the ring last year, didn't see any!
sonny
Post by sonny » Thu Jan 23, 2014 12:42 pm
Chances was you was actually on a Autobahn that had its restriction in place. IIRC There is only 2 Autobahn sections when driving to the Ring and they are retentively small sections.
Point to note
Default/advisory speed is 130kph (81mph). Like Dave says look out for the National speed limit sign (white circle with 4 black diagonal lines).
Also, certain countries/councils can enforce a speed limit on its part of the Autobahn
Post by HYFR » Thu Jan 23, 2014 1:20 pm
Frankfurt to Munich has some pretty epic stretches .... Raced an S5 in my RS 6 to 180mph on that stretch.
The E42 past Brussels is also good, aka the Belgium Straigts, but that's illegal
Kiergrills
Post by Kiergrills » Thu Jan 23, 2014 1:51 pm
Hey Fatneck73
Here is a link to all Autobahns in Germany, and if you use the Screenshot i have attached as a reference you can see all the unrestricted bits.
http://www.autobahnatlas-online.de/Limitkarte.pdf
Kiergrills
Apr Supercharged RS4 B7 Daytona Grey + mods
Porsche 997 Carrera S
Audi S4 4.2 V8 Avant(girlfriends)
Kiergrills
Post by Kiergrills » Thu Jan 23, 2014 2:03 pm
The Map isn't absolutely correct but its - close enough. The only places you will see an Unrestricted Zone change to an 80 is in Construction Areas and these are marked 2Km before. However, it will it will go from Unrestricted to 100 to 80 or possibly 130 to 100 to 80 (maybe even 60). If one encounters a Non-construction 80Km Limit, he has already been driving in a Limited Area (probably 100).
There are a few other things Foreign Drivers should know before driving on the Autobahn.
It is illegal to pass in the right lane.
The Left Lane is for passing. It doesn't matter at what speed you are driving.Also, faster cars expect priority. Suppose you are driving 180 in the Left Lane and there are slower cars in the Right Lane driving perhaps 150 several hundred meters ahead of you. If an Audi R8, Porsche or whatever comes up on you, it is expected you move over even if it requires you to slow a bit. :jump:
On Autobahns with 3 Lanes in each direction, you are required to drive in the Right Lane - not the Middle Lane.
If you suddenly encounter a Traffic Jam, you should operate your Hazard Flashers to warn drivers in back of you.
During Traffic Jams, drivers are required to leave a space between the Left and Right (or Middle) Lanes to allow Emergency Vehicles to pass.
It is illegal to flash headlights or turn on your left turn signal when you are driving behind a slower car in the Left Lane.
Fatneck73
Post by Fatneck73 » Thu Jan 23, 2014 7:52 pm
This is great. Many thanks
Graeme4130
Post by Graeme4130 » Thu Jan 23, 2014 10:48 pm
From my experience, the few remaining unrestricted parts (they're becoming less and less) are generally quite busy during the day, so you're best off at night. However, this time of year is a bit dodgy in the evening because of the changeable weather and/or ice and wet (remember, most of the north end of the country is typically colder than the uk)
You're best off to hit it up late spring and get yourself a warmer dry night
Also, Keep a good eye out for numpties too at night as it's harder to gauge the speed of cars in your mirrors at night if you can only see headlamps, and a 70mph car pulling out in front of you at 170 is a scary experience
toyneg
Post by toyneg » Fri Jan 24, 2014 3:16 pm
Graeme4130 wrote:From my experience, the few remaining unrestricted parts (they're becoming less and less) are generally quite busy during the day, so you're best off at night. However, this time of year is a bit dodgy in the evening because of the changeable weather and/or ice and wet (remember, most of the north end of the country is typically colder than the uk)
i agree with waiting for Spring, i did this last May and had a lovely warm Saturday eve and the roads were really quiet so i could do a couple of max runs, annoyingly hit the limiter so now i have had that removed i'll go back this year hopefully :)
Fatneck73
Post by Fatneck73 » Fri Jan 24, 2014 7:37 pm
Understood and agree. I'm in no rush to get there...just decided after last time that I was going to do my homework this time...couldn't believe how hard it was to get some decent autobahn info!
TimDogg
Post by TimDogg » Sat Jan 25, 2014 1:22 pm
Might be mandated winter tyres also - worth checking.
'56 ST220 (Sold)
'97 ST24 (Sold - loved lots)
Tay56
Post by Tay56 » Sun Jan 26, 2014 12:23 am
Some of the better stretches that I know of which are unrestricted:
Frankfurt am Main (4 lane wide near Airport)
Aachen towards Holland
Stuttgart towards Zingen (A81)
Munich to Ulm
Return to “General Car Chat”
Users browsing this forum: Majestic-12 [Bot] and 62 guests
