Parking Sensors
spikeyboy101
Parking Sensors
Post by spikeyboy101 » Fri Dec 06, 2013 2:27 pm
Do Audi make the most expensive yet cheapest parking sensors in the world ????
in 2 1/2 years of ownership have already replaced 4 parking sensors, now getting error that another one has gone !!!!!
Where is the best place to obtain from ? or is it just a case of paying Audi prices ?
the cueball
Re: Parking Sensors
Post by the cueball » Fri Dec 06, 2013 2:42 pm
yeah they are shocking...
I use a guy on eBay from some eastern country... never let me down and fast delivery... much cheaper too..
:thumb:
Dec369
Re: Parking Sensors
Post by Dec369 » Fri Dec 06, 2013 6:46 pm
spikeyboy101 wrote:Do Audi make the most expensive yet cheapest parking sensors in the world ????
eBay I got them from, 2 for £33 & I painted them with the halfords paint that matches your car. Came out brilliant & work fine, but make sure you get the fully round ones as there are a lot that are different shapes
Ginors4
Re: Parking Sensors
Post by Ginors4 » Fri Dec 06, 2013 8:36 pm
Yep. First job I did when I bought mine. Three of the four sensors failed. I replaced with oem and paid and a and a leg for them. Surely these cost only a few quid to make. But Audi will sell them for what they do because they can.
Gone and miss very much
B7 RS4 Avant Misano Red, lepsons 2-tone black shadow chrome rims, KW coilovers, AMD Stage-1 with valved non-res milltek catback.
spikeyboy101
Re: Parking Sensors
Post by spikeyboy101 » Fri Dec 06, 2013 9:02 pm
Thanks.
Don't suppose you have an ebay link ?
Wierd thing is I owned a B6 S4 for 5 years and never had one sensor fail.
rwilsonrs4
Re: Parking Sensors
Post by rwilsonrs4 » Fri Dec 06, 2013 9:31 pm
ive had 2 fail in 2 1?2 years , its not Audi that make them its Bosch or siemens i cant remember which and from what i have seen they are the same as some Ford ones , in fact apart form the audi number on it i couldnt tell the difference to look at them , but they are about the same price anyhow , i just got replacement ones off Ebay which are prob made in the same factory just rebranded , so far they have been fine at half the price
1/4 mile 12.01 secs 123.5mph
Dec369
Re: Parking Sensors
Post by Dec369 » Sat Dec 07, 2013 6:33 pm
spikeyboy101 wrote:Thanks.
http://bit.ly/1gNlpUt
That's the ones I got, work perfectly :)
spikeyboy101
Re: Parking Sensors
Post by spikeyboy101 » Sat Dec 07, 2013 7:44 pm
Thanks.
Firestarter
Re: Parking Sensors
Post by Firestarter » Thu Jan 09, 2014 6:04 pm
Well my front and rear sensors don't seem to be working. When in reverse the little light on the dash flashes and I get an initial beep.....but then nothing......and the fronts don't do anything??
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT :-)
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre :-)
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
Dec369
Re: Parking Sensors
Post by Dec369 » Thu Jan 09, 2014 6:21 pm
Mine did that at 1st & then started working. How long have you had them fitted ?
coffey555
Re: Parking Sensors
Post by coffey555 » Thu Jan 09, 2014 7:01 pm
My car has been doing that for the last couple of weeks firestarter, long initial beep followed by flashing light on the parking sensor button. Checked module 76 Park Assist with VCDS and it show that my front far right sensor (G252) is faulty. If one of the sensors fails completely I think it turns the whole system off to stop you accidentally driving into things when parking.
You should still be able to read data back from the other sensors by parking behind or in front of another car and using the data logging function.
There are after market sensors on ebay for £16.
Fit one next week so be interesting to see how long it lasts!
Misano Red RS4 B7 Avant
Firestarter
Re: Parking Sensors
Post by Firestarter » Fri Jan 10, 2014 8:56 am
Mine did that at 1st & then started working. How long have you had them fitted ?[/quote]
Hi dude
I haven't fitted anything yet. Just trying to fathom out the cause. Gonna stick VCDS on later and see if it shows any fault codes and if so I guess I need to replace some sensors :audibash: :audibash:
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
adsgreen
Re: Parking Sensors
Post by adsgreen » Fri Jan 10, 2014 12:05 pm
worth giving them a clean - they are essentially like audio speakers so the central "core" needs to move. if its jammed with dirt and crud then it could register a fault.
spikeyboy101
Re: Parking Sensors
Post by spikeyboy101 » Fri Jan 10, 2014 9:26 pm
After all the wet weather we have had mine are working fine again !!!!!!
Firestarter
Re: Parking Sensors
Post by Firestarter » Sat Jan 11, 2014 9:36 am
adsgreen wrote:worth giving them a clean - they are essentially like audio speakers so the central "core" needs to move. if its jammed with dirt and crud then it could register a fault.
Cheers bud :beerchug: . Now the $64000 question.....how do I remove them to clean? Is it a bumper off job :thumbsdown:
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Users browsing this forum: Google Adsense [Bot] and 350 guests
