Spark Plug Life / transmission / diff oil life
sync24
Post by sync24 » Fri Nov 15, 2013 10:11 am
I am planning a bit of a interim service. My spark plugs where replaced at 49000 miles, about 18 months ago - I now have 65000 on the clock - time to replace? How about DIFF/Transmission oil - should this be replaced? I don't see it ever done in my service history.
Apart from the usual cabin filter ETC anything else that should be done? Brake Fluid was replaced around 10 months ago - so that does not need doing. Oil was done 1.5k ago.
Cheers :blackrs4:
esp_mm-270
Re: Spark Plug Life / transmission / diff oil life
Post by esp_mm-270 » Fri Nov 15, 2013 10:48 am
I would get the 'box and diff fluids done. Mine was by previous owner at about ur mileage by MRC.
PJC
Post by PJC » Fri Nov 15, 2013 11:06 am
Plugs are five years iirc
adsgreen
Post by adsgreen » Fri Nov 15, 2013 12:05 pm
fuel filter is cheap and easy.
Surrey Sam
Post by Surrey Sam » Fri Nov 15, 2013 12:39 pm
Spark Plugs are every 6 years/60,000 miles. So they will be fine unless the car has been running poorly leading to premature fouling.
Perhaps worth getting the aircon serviced if there is no record of it being done - the oil used in the refrigerant helps keep the O-rings from drying out and get it deodorised at the same time too, keeps it smelling nice.
Some maybe sceptical (I was) but a while back I ran some Redex fuel line cleaner through mine, at the next fuel fill up...for the first time ever...I saw 300+ mile range come up on the fuel trip and a slight increase in the MPG figure. Nothing amazing, but worth the product cost.
sync24
Post by sync24 » Fri Nov 15, 2013 1:46 pm
Surrey Sam wrote:Spark Plugs are every 6 years/60,000 miles. So they will be fine unless the car has been running poorly leading to premature fouling.
Cheers Sam - Had my aircon re gassed in the summer [was running at 75%], I too ran RedEx through mine recently. I didn't see a increase in MPG but I am sure I noticed a subtle improvement [might have been the placebo effect though]. What I have noticed is that combined with a recent oil change and a move to Shell V-Power Nitro+ {what a great name for 'fuel'] from Momentum 99+ has given me pretty much another 45 miles per tank - I regularly see 340 miles out of a tank doing motorway miles each day - I real bonus! :biggrin2:
sync24
esp_mm-270 wrote:I would get the 'box and diff fluids done. Mine was by previous owner at about ur mileage by MRC.
Yep - gonna get them done Mark
Teutonic_Tamer
Post by Teutonic_Tamer » Mon Nov 18, 2013 11:45 pm
Consider replacing the coolant too.
And use only genuine fluids in the gearbox and rear diff - there are no aftermarket products approved for these.
Definately replace the fuel filter - but make sure the tank is less than a quarter full.
Sean - Independent Motor Vehicle Tech (ret'd)
'07 Audi B7 RS4 (with ceramic brakes) - WOW!
'06/7 VW Golf Mk5 GTI 2.0T FSI DSG 5dr
'03 Audi B6 S4 4.2 V8 6sp man (gone)
Users browsing this forum: No registered users and 188 guests
