S4 Purchase
S4 Purchase
Hi Folk's,
So i've jumped into S4 ownership just recently with the purchase of a 53 plate B6 Avant with (allegedly) 88k on the clock. The few MOTS i have do tally with the mileage.......
My question........the infamous diesel impression on start up i.e the rattle. Now the reason i bought this car was it came with a receipt for 2k worth of work done by a garage changing the chains, tensioners and guides with original Audi parts just 6 months ago......... and it still sounds like a bag of nails on just about every start up, albeit for only a max of 2 seconds. I phoned the garage the other day who carried out the work, who said the car was a runner when it came in for repair, only a broken guide to blame so there was no other serious issues, and that this noise is perfectly normal and acceptable. Well let me tell you, if i went into an Audi dealership 10 years ago to buy one of these machines at whatever Galactic price, and it sounded like a gardner 180 on start up, id tell the salesman who insisted this is normal, to poke his car take my word for it!!??.
I changed the oil today with a genuine filter, and used Shell Helix 5w 40 in a vein hope the oil would be a bit thicker so not to drain from the tensioners........no change. Should i keep the Impreza??!!!
Your thoughts.....?
Cheers.
Your thoughts.....?
Cheers.
Re: S4 Purchase
First thing to do is hook up Vagcom as it will confirm whether or not the ecu mileage tallies with the instrument binacle....
If the rattle is just as bad with fresh oil that doesn't sound great
Pi Quattro
Re: S4 Purchase
Gus, where did you get it from?
Re: S4 Purchase
From a well known internet website, private deal. Taking the chance on the merit of work carried out as I'd known about these issues before!. It was quiet when I picked it up, travelled home near 500 miles and it's started being slightly more noticeable since.
Cheers.
Cheers.
Re: S4 Purchase
i've heard lots of owners say this is normal and not to worry.. altho, touch wood, mine doesnt do it - bit worrying tho
hope you get it sorted - as they're great cars
goose
goose
Current:
'08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
'72 Sunburst Yellow VW Karmann Ghia Coupe|1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 interior
Past:
'06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
Past:
Re: S4 Purchase
mnine does it from cold (B7 S$) - have read that it is normal - mine is a 61k 05 plate , mileage verified.
Re: S4 Purchase
Mine rattles for a couple of seconds.. Not too worried - YET!! 06 plate with 52k. As above, I've read/heard It's meant to be normal. My mate's car does it too. It doesn't sound like a bag of spanners though, hard to describe. You should post up a sound clip.
Current - 07 Sprint Blue RS4 Avant Black optics / Buckets / FBSW / MRC Stage 2 / De flapped Manifold / CAF / BMC filter / Decat / Non Res Miltek / Bilstein B16's / Tarox discs, pads and lines / H&R ARBs / 19x9.5 Ispiri ISR1 wheels / MPSS tyres / DTM carbon splitter
Previous - 06 Sprint Blue B7 S4 Avant JHM 91 tune / 2.5" Custom Cat-less DP's / Miltek Non Res Cat back / BMC filter / H&R springs / 19" Fox MS007 wheels/Good Year F1's / EBC TG discs / Yellow stuff pads
Re: S4 Purchase
Mine is opurely on inital turn over, no longer.ASC wrote:Mine rattles for a couple of seconds.. Not too worried - YET!! 06 plate with 52k. As above, I've read/heard It's meant to be normal. My mate's car does it too. It doesn't sound like a bag of spanners though, hard to describe. You should post up a sound clip.
Re: S4 Purchase
Yup same
Re: S4 Purchase
Thanks guys for the quick responses. When I say a bag if spanners I'm probably exaggerating, and it is very brief on start up, but should this still happen with chains etc just done?. That's why I'm baffled as to various experts including Audi techs claiming it is normal, when it's such an off putting sound, and surprises me any were sold doing this from new?!.
Runs as normal and is a great car, just hard to believe it can be such a weak point.
Cheers.
Cheers.
Re: S4 Purchase
I have heard of cars still rattling once the service is done yes. BUT I would make sure that's definitely the noise you're hearing and get a second opinion from Specialist before making a decision. There's loads of info on other forums about chain rattle, allot of folk saying 'don't worry it's normal", also allot of folk saying "oh my god it's a time bomb, quick pull the engine!"
I was concerned a while back, I even put it into Audi, they came back saying it sounded normal when they started it, nothing untoward so that kind of satisfied me. There will always be a small niggle at the back of my head though!
Re: S4 Purchase
We have an '04 S4 Cab and when we first got it, it had the chain rattle but it was on the original long-life servicing and skinny 0/30w? oil. I changed the oil (and servicing intervals) to 5/30 and the rattle is completely gone if the car is used every day and only lasts 1 second or so if the car is left over the weekend.
