cylinder numbering
5.2 V10 40v Naturally Aspirated - 429bhp
tmg
cylinder numbering
Post by tmg » Sun Sep 01, 2013 8:24 pm
Hey
so about to replace a coilpack, and just wanted to confirm the cylinder/ coilpack order is as follows:
5 - rear - 10
4 -------- 9
3 -------- 8
2 -------- 7
1 - front - 6
looking at the car from the front
t.
tmg
Re: cylinder numbering
Post by tmg » Mon Sep 02, 2013 12:07 am
as a note, the V8 is detailed here (and seems to be the same as my guess at the S6 v10 is)
http://forum.rs246.com/viewtopic.php?f= ... ng#p547228
cheers
t.
Post by Shoppinit » Mon Sep 02, 2013 7:46 am
I am 99.9% sure that that is the right layout.
Can't find anything on Elsawin, but found this document about the VW Tourag V10:
http://www.precisionframe.com/Touareg/i ... /v10_2.pdf
I can't believe they would arbitrarily change the way they order the cylinders.
tmg
Post by tmg » Mon Sep 02, 2013 5:05 pm
cool
thanks man - I changed the coil packs (6&7) and it seems to have fixed the misfire.
cheers
t.
Post by Shoppinit » Mon Sep 02, 2013 5:17 pm
Are Audi still having coilpack issues? Sometimes the misfire reporting isn't very accurate. It says 5 so you change 5 and it still comes back. Because it meant 6, really. Sometimes if your misfire doesn't go away right away then you can try changing the new coil pack's position. Or change them all, but if you're a greedy bugger and have 10 cylinders, that can get pricey. :)
tmg
Post by tmg » Mon Sep 02, 2013 6:53 pm
yeah :)
its hunting between 6, 7 and 8. I've swapped out 6&7 as they are the ones being reported the most :) and have two more on order so I can do 8 and have a spare. mostly it happens when i get stuck in traffic for a while and the engine gets heat soaked, so hopefully this will sort it out.
annoying that etka doesnt have this chunk of info in it though
t.
Golfather
Post by Golfather » Fri Sep 13, 2013 4:27 pm
Its a free recall on the S6. Give ur dealer a call.
tmg
Post by tmg » Sat Sep 14, 2013 5:47 pm
unfortunately here (ireland) they havent issued a recall, and claim no knowledge of anything similar. I think there is only one original coilpack left now anyhows :( after the last round of 3
t.
Return to “S6 (C6 Typ 4F) 2006-2011”
Users browsing this forum: No registered users and 5 guests
