Gearbox woes........
WAFWOTTBI
Post by WAFWOTTBI » Fri Jul 05, 2013 6:34 am
Think i may be digging deep into my small Audi slush fund very soon,gearbox when cold,clunky change between 1st and 2nd,ok when warm,no problems when fully warmed up,can only presume this will get worse,on a particular cold morning,went into limp mode,stopped,switched off,restarted,ok,warm days,as long as not driven hard til warmed up,seems ok.........used kickdown,very loud clunk...won't be doing that again til sorted......think car will be heading north of Portsmouth to get sorted,will be firing off a few e-mails this weekend for advice/quotes,is it worth having pre-cats removed at same time ????..has a stage one map already,will it need tweaking with pre-cats removed ?????...cheers WAFFY... :blackrs4: :(
RS 6 Avant,
Ebony black mettallic,03 plate,
H&R coilovers,
miltek back boxes,
pirelli p zero's,
Re: Gearbox woes........
Post by chunky79 » Fri Jul 05, 2013 6:51 am
If you are having the downpipes gutted then yes your map will need tweaking, well worth doing while your box is out. Is it an MRC map currently? Sorry to hear about your box.
WAFWOTTBI
Post by WAFWOTTBI » Fri Jul 05, 2013 12:03 pm
Not mrc at present,might have map looked at,and possibly adjusted/changed........
RS 6 Avant,
H&R coilovers,
miltek back boxes,
pirelli p zero's,
Post by Shoppinit » Fri Jul 05, 2013 12:04 pm
JCViggen posted some data of a precatless standard mapped car.
RS6JJL
Post by RS6JJL » Fri Jul 05, 2013 10:42 pm
change the gearbox fluid first, mine was like new once that was done check for fault codes with Vagcom to follow up before booking in chances are though its logged a fault on the automatic transmission module
KV53 YML - RS6 Avant - Stolen Hampshire
RS 51X CS - RS6 Avant - Sold
Revolvo
Post by Revolvo » Sat Jul 06, 2013 7:52 am
RS6JJL wrote:change the gearbox fluid first, mine was like new once that was done check for fault codes with vagcom to follow up before booking in chances are though its logged a fault on the automatic transmission module
Out of curiosity, did you have the high revs, then slamming into gear sympton which the ATF change cured or did you change the ATF before any of that arose? Thinking my own gearbox sounds a bit "coarse" at the moment and wondering if a pre-emptive fluid change might be the way forward.
If the slamming thing happens, does it mean that not all is entirely lost if the ATC has not gone into limp mode? Wanna be sure to catch (hopefully in time) it if it does happen.
And best of luck wafwottbi with yours, hopefully not as expensive for your repairs as may be feared.
2002 Mugello blue RS6, silver interior. FASH.
Goblin-eater under the bonnet.
81 Mini 850 > 87 Mini Cooper > 68 Volvo Amazon > 81 Golf GTi > 90 Corrado G60 > 89 320i > 02 Blue Thunder.
RS6JJL
Post by RS6JJL » Sat Jul 06, 2013 11:21 pm
Yeah had high revs and slamming into gear on full acceleration, was really noticeable in all gears after a while, had the fluid changed and things very much improved, garage said fluid was clean that came out no contaminants, can be black sludge i was told on here bad sign! as they were reluctant to do the job i insisted on new fluid, filter, etc and it cleared the fault code
i bet you this is the fault you will find logged possibly you may be lucky though in this early stage, check with Vagcom asap!
17125 - Torque Converter Clutch Circuit Performance or Stuck Off.
P0741 - 35-00 -
because of having the gearbox service done im convinced i saved the box from going into limp, where it physically gets stuck in gear and you can't move it!
i would start saving though for your slush fund £3.5k will probably be needed in the end to sort matters out long term with the gear box, reconditioned TC, however changing the fluid first would be right on my no.1 list of jobs if i was you
im local to you if your not far from portsmouth if you want a scan with Vagcom, i've got rid of my rs6 this week but still have Vagcom
WAFWOTTBI
Post by WAFWOTTBI » Sun Jul 07, 2013 7:10 am
Thanks for all the replys guys,car has had a yearly ATF change each year for the three years we've had her,only been in limp mode a couple of times,its when its cold,when warm not to bad,when fully warmed up you wouldn't know there was a problem.......although don't use kickdown at mo,it slams down,especially if dropping 2 gears.......so visit to Oxford looming.....got to break bad news to other half...wish me luck....although she does love the car........ :blackrs4: :(
RS 6 Avant,
H&R coilovers,
miltek back boxes,
pirelli p zero's,
WAFWOTTBI
Post by WAFWOTTBI » Sun Jul 21, 2013 7:27 am
Had quote from Doug at MRC,car may be sitting for awhile,couple of things to try,cheers Doug,still thinking new box,need to get more pennies together......she will be fixed though,just not sure when....... :blackrs4:
RS 6 Avant,
H&R coilovers,
miltek back boxes,
pirelli p zero's,
WAFWOTTBI
Post by WAFWOTTBI » Tue Jul 30, 2013 7:15 am
WAFWOTTBI wrote:Had quote from Doug at MRC,car may be sitting for awhile,couple of things to try,cheers Doug,still thinking new box,need to get more pennies together......she will be fixed though,just not sure when....... :blackrs4:
30th july,booking her in for a gearbox service,getting a couple of things checked that have been suggested, ( thanks Doug...MRC..... )...fingers crossed,if not,will be sitting her for a while,to get pennies together....... :blackrs4:
RS 6 Avant,
H&R coilovers,
miltek back boxes,
pirelli p zero's,
WAFWOTTBI
Post by WAFWOTTBI » Sat Sep 21, 2013 7:00 am
Just a quick update on gearbox,after talking to Doud at MRC,although have been having gearbox oil changed yearly,Doug suggested putting a new oil pick up pipe in,which has now been done along with gearbox service/oil ,early days yet,car transformed,back to normal,will keep monitoring,fingers crossed........will give it a month,then i think bottle of favourite tipple heading Dougs way !!!!!!!...... :blackrs4: Waffy........
RS 6 Avant,
H&R coilovers,
miltek back boxes,
pirelli p zero's,
Post by chunky79 » Sat Sep 21, 2013 8:28 am
Wonder if yours had the wrong length pick up pipe on then?
mavada
Post by mavada » Sat Sep 21, 2013 8:53 am
...where did you get the kit from?
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
WAFWOTTBI
Post by WAFWOTTBI » Sun Sep 29, 2013 8:18 am
chunky79 wrote:Wonder if yours had the wrong length pick up pipe on then?
According to the guy who looks after mine,the new oil pick up pipe had a cloth/gauze filter in middle of it,so possibly after 10 years of running,mine may have been slightly or partialy blocked,running like a dream at mo,give it a few more weeks,it used to be worse in colder weather...not missing a beat at mo......fingers crossed... :blackrs4: WAFFY.......
RS 6 Avant,
H&R coilovers,
miltek back boxes,
pirelli p zero's,
WAFWOTTBI
Post by WAFWOTTBI » Sun Sep 29, 2013 8:20 am
mavada wrote:...where did you get the kit from?
Mav,he just ordered the pipe from Audi,along with the stuff he needed for gearbox oil change....... :blackrs4: WAFFY
RS 6 Avant,
H&R coilovers,
miltek back boxes,
pirelli p zero's,
Users browsing this forum: No registered users and 137 guests
