Hi all, I have recently bought an 06 RS4 until I find the right C6 avant. The car has covered 110k with full main dealer history. All seems ok with the car apart from when you accelerate hard it momentarily hesitates for a split second. It doesn't seem to be at any particular revs and it just does it the once and then climes through the rev range fine. Anybody have any experience of similar fault? Want to get it sorted but as the C6 could pop up at anytime I'm not sure how long I'll have the B7 for, and therefore don't want to spend to much on it.
Andrew
RS4 slight hesitation under power
Re: RS4 slight hesitation under power
Probably need to log with Vag Com to see what's going on.
Might be worth recallibrating the throttle as it might be out (I've had similar symptoms before with a misaligned throttle on a different car).
Just need access to Vag Com (tbh if you are continuing with fast audi ownership it's a worthwhile investment)
Also, you posted in the S4 section.
Users browsing this forum: No registered users and 20 guests
