8mm spacers - before and after
sync24
Post by sync24 » Thu May 02, 2013 6:52 pm
Just a quick post for reference really, I went from 275x30 Vred's today to 255x35 Goodyear's with 8mm spacers. Thought those who where considering it would like to see before and after pics. :thumbs: to Event tyres for fitting and :thumbs: to virdee for the spacers/re-sized bolts including lockers. Amazing what 8mm will do and from the back the car's looks much better - KWv3 coilovers next week :biggrin2: more pics to come
Cheers.
Kev.
Before [ 275x30's ]
After [ 255x35's ]
otterolly
Re: 8mm spacers - before and after
Post by otterolly » Thu May 02, 2013 7:43 pm
looks spot on.....are you going lower on the v3's ?
Big-blu
Post by Big-blu » Thu May 02, 2013 7:45 pm
Looks awesome!
Today I had to change my order from 10mm H&R spacers to 8mm because apparently they no longer make the 10mm with the 150mm hub diameter.
Your pictures definately reassure me that 8mm and 275/30 v12 tires will look great.
sync24
Post by sync24 » Thu May 02, 2013 7:56 pm
otterolly wrote:looks spot on.....are you going lower on the v3's ?
Yep - just a little at the back but the front for sure - I want to match the front to the rear ride height without it being silly.
scaghead
Post by scaghead » Thu May 02, 2013 8:01 pm
Looks good fella..I am waiting for my re ordered 265/30s to turn up,rather than my original decision of 275/30s..which means I can also keep running my spacers as well...
jaysrs4
Post by jaysrs4 » Thu May 02, 2013 8:04 pm
Humm, interesting. I'm just about to do some spacer purchasing.
There seem to be a few brands doing 10mm hubcentrics still, but those 8mm's are looking pretty good up rear.
Oooo I do like girth!
Only just coming from the Golf R32 scene, what does surprise me are a lot of you like running pretty huge width tyres, 275's! That really surprises me.
sync24
Post by sync24 » Thu May 02, 2013 8:07 pm
Big-blu wrote:Looks awesome!
Your pictures definitely reassure me that 8mm and 275/30 v12 tires will look great.
Uhm - :o I would double check your figures as 275x30 tyres are 20mm wider and with 8mm spacers you are likely to go beyond the wheel arch.
I originally wanted spacers with my 275's and Virdee [a spacer supplier/fountain of knowledge here] in as many words stopped short of not selling them to me.
I had a choice of 275's with no spacers or 255's with 8mm spacers to go with my setup especially as I am going to KWv3's
I would strongly advise you give him a call - I am sure he would not mind giving you the correct advice.
sync24
Post by sync24 » Thu May 02, 2013 8:14 pm
jaysrs4 wrote:but those 8mm's are looking pretty good up rear
I am amazed at how much 8mm a side can totally change the way the car looks :bowdown:
jaysrs4 wrote:a lot of you like running pretty huge width tyres, 275's! That really surprises me.
I think a lot of people run 275's as they offer a bit more rim protection plus they do look nice! :)
jaysrs4
Post by jaysrs4 » Thu May 02, 2013 8:23 pm
I'm gonna get flamed here Sync, but I've always loved a bit (not too much) stretch and a tasty drop = a lovely stance (runs and hides)!!!!
I know, I know, less road contact ruins handling!
I guess I'm just getting used to a proper drivers car that all it realistically needs is 16mm widening and a 25/30mm drop, even then I guess that may be a tad too much for some.
Big-blu
Post by Big-blu » Thu May 02, 2013 8:28 pm
I did my research and found that many guys run 275/30 pss with 10mm spacers all around with minimal rubbing under full load and hard cornering. I went with 8mm and 275 v12's (which are thinner than the pss) so should be good.
I will report back after install and let you know if they work out.
toyneg
Post by toyneg » Thu May 02, 2013 8:28 pm
Looks great! How much does this cost out of interest?
Btw - that paint looks awesome, have you had the car detailed?
sync24
Post by sync24 » Thu May 02, 2013 8:44 pm
toyneg wrote:Looks great! How much does this cost out of interest?
I got 4 x 8mm H&R spacers,20 new longer bolts & 4 new longer locking wheel bolts for £215 from Virdee
toyneg wrote:that paint looks awesome, have you had the car detailed?
Thanks! I've not had it done but the previous owner may have had some minor detailing last summer - I just keep it clean by hand washing weekly :thumbs:
It's going in for a front and rear respray and a 5 day detail in June - I'll be well pleased if it looks anywhere near as nice as Sila's :notworthy:
toyneg
Post by toyneg » Thu May 02, 2013 9:15 pm
Cheers for the info! Another thing for me to add to the list, it's getting quite long now!
Yeah silas' looks awesome, I have a detail booked for the 24th, can't wait!! :-)
Post by MikeFish » Thu May 02, 2013 10:09 pm
It doesn't look so much as detailed but just very clean, but Kev your arches look huge in that first pic!!!!! (that's huge in a good bulbous way!)
275 and 8mm spacers might be too much, 275 and 10mm is defo too much as I said in a post earlier today as the tyre is 20mm wide (10mm on inside and 10mm on the outside) added to a 10mm spacer is the equivalent of a 20mm spacer with the standard tyres and that is just too much with any weight in the back.
Big-blu
Post by Big-blu » Thu May 02, 2013 10:25 pm
MikeFish wrote: 275 and 8mm spacers might be too much, 275 and 10mm is defo too much as I said in a post earlier today as the tyre is 20mm wide (10mm on inside and 10mm on the outside) added to a 10mm spacer is the equivalent of a 20mm spacer with the standard tyres and that is just too much with any weight in the back.
This thread lists a handful of guys running 275/30 with 10mm.
http://forums.quattroworld.com/rs4b7/msgs/95440.phtml
Hoping the 8mm works, but I do appreciate the advice.
-Ryan
Users browsing this forum: Google [Bot] and 191 guests
