Secondary air pump
ctsui35
Secondary air pump
Post by ctsui35 » Tue Apr 30, 2013 12:07 am
Hi all, need some help. After changing the Secondary air pump, does the car need to be reset with Vagcom to take of engine management light.
Re: Secondary air pump
Post by Shoppinit » Tue Apr 30, 2013 8:19 am
If you've fixed the problem, it'll eventually go off. Eventually.
sweegie
Post by sweegie » Tue Apr 30, 2013 11:40 am
It's only FIVE POUNDS for an ebay special blue KKL cable and VCDS Lite is the mighty sum of ZERO POUNDS!
Go on... Splash out a little ;)
Recycling dinosaurs for fun
ctsui35
Post by ctsui35 » Tue Apr 30, 2013 6:34 pm
Could you pls give me the link to one that works. As the last lead, I bought didnt work. Would be much appreciated.
sweegie
Post by sweegie » Wed May 01, 2013 1:27 pm
Sure, no probs. I use something very similar to this with much success:
KKL Cable Link
Ignore any driver CD you get with it and use these drivers direct from FTDI:
Drivers Link
I have a pretty comprehensive array of diagnostic tools & my trusty cheap blue kkl cable is the one i turn to most.
ctsui35
Post by ctsui35 » Wed May 01, 2013 7:10 pm
Thanks Sweegie for the link.
The engine management light has gone now. Phew.
