VCDS - Adjusting Headlights for Europe
toyneg
Post by toyneg » Wed Mar 20, 2013 1:12 pm
Hi Guys, I am planning a trip to Europe in May, I understand I have to get the headlights adjusted via VCDS which Audi charge quite a bit for. is there anyone around Hampshire that has this that might be able to assist for some cash. as I say wont be until late May
unless there is another way to do this manually?
thanks as always
Boggle73
Re: VCDS - Adjusting Headlights for Europe
Post by Boggle73 » Wed Mar 20, 2013 1:29 pm
PetrolDave wrote:
Boggle73 wrote:If there is a switch to knock over to Europe driving that would be really handy.
It's not a switch, it's a setting with VAG-COM (VCDS) that puts the headlights into "Tourist Mode".
I take my netbook and VAG-COM lead with me and change the setting while we're in the tunnel. DEalers quoted me £100 to set them to Tourist Mode, and another £100 to reset them back again!
Fully compliant, i.e. dip the other way, means changing the headlamps to LHD ones.
Think the code was 050 or 051
My local VW/Audi backstreet garage did it for £10.00
The only problem is getting to and from the tunnel legally, I just planned my trip to and from tunnel in daylight.
Jay.
Past - TTRS - Suzuka Grey
toyneg
Post by toyneg » Wed Mar 20, 2013 1:33 pm
Jay.
awesome! many thanks
murph7355
Post by murph7355 » Wed Mar 20, 2013 1:33 pm
Do foreign drivers bother when they come over here...?
Gizmo68
Post by Gizmo68 » Wed Mar 20, 2013 1:40 pm
Depending where you are departing the UK from, I am half way between the Channel Tunnel and the port of Dover.
VCDS HEX+CAN owner - covers all VAG cars (PM me if you require VCDS coding in Kent)
Gizmo68
Post by Gizmo68 » Wed Mar 20, 2013 1:41 pm
murph7355 wrote:Do foreign drivers bother when they come over here...?
No they don’t (as a rule)
But why lower yourself down to the level of others?
toyneg
Post by toyneg » Wed Mar 20, 2013 1:48 pm
Gizmo68 wrote:Depending where you are departing the UK from, I am half way between the Channel Tunnel and the port of Dover.
cheers Gizmo, I'll give the local Audi independant a shout, I'll see how much they want for it, otherwise I'll give you a shout. leaving from the channel tunnel.
thanks again
Dom81
Post by Dom81 » Wed Mar 20, 2013 2:03 pm
With the normal RHD setting, the beam projects much further along the NS kerb / hedgerow then it does down the centre of the road. My understanding is that the Tourist setting doesn't alter the left / right angle of the beam - it just dips the whole thing down to prevent the extended range part from dazzling oncoming traffic when driving on the right. Certainly from experience, the lights just appear more centered and slightly less effective overall
On this basis, Tourist mode won't be dazzling anyone on the way to the ferry / train - just not delivering a particularly brilliant beam...
2007 Daytona RS4 Avant
Boggle73
Post by Boggle73 » Wed Mar 20, 2013 2:04 pm
The required code is on here somewhere but I can't find it, sorry.
Make sure your also prepared with the other bits you need too.
http://www.theaa.com/motoring_advice/to ... ipment.pdf
They do enforce the law if you get stopped, best to be on the right side.
Boggle73
Post by Boggle73 » Wed Mar 20, 2013 2:07 pm
Forgot to add that it is now compulsory to carry a breathalyser kit in France.
Hope this helps.
murph7355
Post by murph7355 » Wed Mar 20, 2013 2:13 pm
Boggle73 wrote:Forgot to add that it is now compulsory to carry a breathalyser kit in France.
Hope this helps.
This wasn't being enforced when I went over in October, despite much confusion as to whether it was in play or not. AA site helped at the time.
Is it definitely an requirement now?
murph7355
Post by murph7355 » Wed Mar 20, 2013 2:15 pm
Cost. And likelihood of it being a problem (whenever I've driven on the continent, night driving has been rare).
Gizmo68
Post by Gizmo68 » Wed Mar 20, 2013 2:31 pm
Dom81 wrote:With the normal RHD setting, the beam projects much further along the NS kerb / hedgerow then it does down the centre of the road. My understanding is that the Tourist setting doesn't alter the left / right angle of the beam - it just dips the whole thing down to prevent the extended range part from dazzling oncoming traffic when driving on the right. Certainly from experience, the lights just appear more centered and slightly less effective overall
Correct, all the tourist setting does is ‘flatbeam’ the headlights so they no longer kick up to the left…. you may also get a warning in the DIS that tourist setting is enabled.
Any AFS settings (cornering headlights) will also be disabled.
Hope this helps.
The french have (a couple of weeks ago) announced they will no longer be enforcing motorists to carry a breathalyser.
Boggle73
Post by Boggle73 » Wed Mar 20, 2013 2:37 pm
Oh good, it was supposed to come in on 1st march I think.
We are taking a Europe trip in July, saves me spending another £10 on a breathalyser.
pDkALO
Post by pDkALO » Wed Mar 20, 2013 3:53 pm
Gizmo68 wrote:Correct, all the tourist setting does is ‘flatbeam’ the headlights so they no longer kick up to the left…. you may also get a warning in the DIS that tourist setting is enabled.
I used tourist mode for Le Mans Classic trip last summer, and was pleasantly surprised that adaptives were still fully functional all the time. I got a warning each time I switched the ignition on, but that was it.
I really cannot imagine that any UK plod would make an issue over your lights being in tourist mode for a trip to / from the docks (or even if they were able to tell the difference).
Users browsing this forum: No registered users and 415 guests
