7th gear issue's?
4.2 V8 32v FSI - 444 bhp
Audi Steve
7th gear issue's?
Post by Audi Steve » Sat Mar 16, 2013 10:13 pm
Ok so I've only done 250 miles in it so far but in D it is reluctant to change into 7th until 59 mph?, in manual it will drop in at 36, the demo I've tested twice goes to 7th at 36 when in D but has done 4.5k, is the still a learning process on the S Tronic which could still be learning?
RSphantom
Re: 7th gear issue's?
Post by RSphantom » Sat Mar 16, 2013 11:37 pm
Audi Steve wrote:Ok so I've only done 250 miles in it so far but in D it is reluctant to change into 7th until 59 mph?, in manual it will drop in at 36, the demo I've tested twice goes to 7th at 36 when in D but has done 4.5k, is the still a learning process on the S Tronic which could still be learning?
I've got exactly the same problem with mine. When did you get yours, mines at the dealership being looked at?
Also where's the pics?
2019 RS3 4 door - Gone
535dboy
Post by 535dboy » Sun Mar 17, 2013 7:36 am
No such problems with mine
Dumps it in 7th quite early (particularly in comfort mode) or I can do manually with no problems.
Currently :
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
Seat Ibiza excellence Lux!
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2017 AMG E class wagon
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
drybeer
Post by drybeer » Sat Mar 23, 2013 8:13 am
it does depend how you've got the drive select mode set and of course engine temp. In comfort it should go up the rations much sooner than you're describing.
C7 A6 allroad 3.0TDi.
Tiguan 2.0TDi R-line
535dboy
Post by 535dboy » Sat Mar 23, 2013 9:52 am
drybeer wrote:it does depend how you've got the drive select mode set and of course engine temp. In comfort it should go up the rations much sooner than you're describing.
This
Currently :
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2012 Audi RS4 (B8)
RSphantom
Post by RSphantom » Wed Mar 27, 2013 10:14 pm
Quick update on the 7th gear issue. Went to the dealership last week and they took some diagnostic readings off the gearbox and sent them off to Audi UK who have now sent them to "Ze Germans" who are looking into it.
However, I went for the first long drive in the car today since getting it and it seems to have fixed itself. Around 20 miles into the journey the gearbox started changing up when expected and continue to perform faultlessly. When I started up for the return journey I was expecting it to go back to its old ways, but no, good as gold all the way home.
Don't know why the only thing I can put this down to is that I've just gone past the 500 mile mark and the first 500 miles the gearbox was kind of running itself in.
Anyway other drive in it tomorrow so we will see if it was a one off or not. It definitely helps with the economy as my trip today (around 70 miles) it averaged just under 26mpg this being on single track A roads and not driving like Miss Daisy.
Post by MikeFish » Wed Mar 27, 2013 10:46 pm
Audi Steve you need to go for a 250 mile drive tomorrow to see if it makes a difference on yours too.
RS Owner
Post by RS Owner » Tue Apr 30, 2013 10:37 pm
Can I ask how you normally drive these DCT gearboxes? is it usual to have it in D (auto) or change manually
Gone : 2017 M3 CP
535dboy
Post by 535dboy » Wed May 01, 2013 6:32 am
RS4Owner wrote:Can I ask how you normally drive these DCT gearboxes? is it usual to have it in D (auto) or change manually
98% of the time I drive it manual however I have noticed better economy in drive!
Currently :
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2012 Audi RS4 (B8)
Brooner
Post by Brooner » Wed May 01, 2013 7:50 am
Set in dynamic in D goes into 7th about 40 but usually in S mode then manual for a B road blast no issues so far
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Nickyboy
Post by Nickyboy » Wed May 01, 2013 8:22 am
Same here. When in manual you can time the up-shift such that you get the awesome throttle blip without hammering it. on mine it's above 5k rpm, yours probably about 6.5k rpm.
What speed are your guys RS4's going when you change up at the limit in 1st and 2nd?
2011: 2.0T FL Octavia VRS
2010: 1.8T Octavia VRS
drybeer
Post by drybeer » Sun May 12, 2013 7:13 pm
Brooner wrote:Set in dynamic in D goes into 7th about 40 but usually in S mode then manual for a B road blast no issues so far
Last night's drive had the car suitably warmed up, and once in 7th it was available when I decelerated into a 30 limit to as low as 28mph ish with no probs.
Users browsing this forum: Mcw543 and 36 guests
