VCDS killing my battery
Re: VCDS killing my battery
I always have the car running when using it. If you run a test when the engine is off don't you get loads of errors?
The only errors ou will get is what is actually present, turn the DRL’s off if you want then do a scan whilst the ignition is on but not running.MikeFish wrote:If you run a test when the engine is off don't you get loads of errors?
VCDS HEX+CAN owner - covers all VAG cars (PM me if you require VCDS coding in Kent)
