MOVED Brakes - do front B7 discs work with B5 calipers
ianw
Post by ianw » Wed Jan 30, 2013 10:17 am
before you flame me for being crazy - yes I have spent the last few days getting up to speed with current options and I know the B7 calipers are the best thing since slice bread etc.
Once again the brake issue has arisen, last winter I had to replace the rear calipers which had seized and stayed with the original b5 calipers, the disks however need replacing and the service light has now lit meaning a trip to the stealers is imminent plus I have a trip to germany coming up in a couple of months.
Bearing in mind I have a lot of mouths to feed and the car is not used for trackdays (I ride motorcycles for adrenilin kicks) its mainly used these days around town with the occasional 250+ kph jaunts over to Germany I am wondering what the best option is. Stuff here is very expensive compared to the uk and its a hassle to get things shipped from UK
anyway here are my options
1. replace discs with standard B5 ones again cost 1800 plus pads
2. replace discs with quattro "drilled" B5 upgrade cost 2600 plus (pagid) pads
3. Replace front with B7 discs and calipers cost 3500 plus would need drilled rears to match front as MOT testers would pick up solid rears and drilled fronts so quattro sports drilled disks 1300 plus pads.
If I go option 1 or 2 I can later maybe next year update the front calipers to the B7 versions but I am not fully sure it will be necessary with option 2
OR if the slightly bigger B7 front discs fit with the B5 calipers would that be a better route than option 2 again I would need drilled discs on the rear to not draw to much attention from the MOT tester - has anyone tried that
I also see reference to phaeton discs are they also an option do they use the same calipers
At the moment I am favoring option 2 as its a good compromise and an upgrade from standard and hopefully the disks don't rust as fast as standard ones and then maybe next year upgrading the calipers to B7.
As I will do the work myself option 2 is easy to do as no bleeding would be required, yes I know its not too difficult to do with the right equipment but is cold here at the moment and the 6 nations :beerchug: is about to start so the less time outside the better :)
A brit in the Alps - Bought my Misano new in 2001 and still have it
klauster
Re: Brakes - do front B7 discs work with B5 calipers
Post by klauster » Wed Jan 30, 2013 3:54 pm
you have posted this in the classifieds? You might have more luck in the B5 section
ianw
Post by ianw » Wed Jan 30, 2013 4:15 pm
Oops sorry - can't delete this but will post it where I originally intended and as you recommended
ianw
Re: MOVED Brakes - do front B7 discs work with B5 calipers
Post by ianw » Wed Jan 30, 2013 4:18 pm
If a mod is looking can you remove this please as I have posted it in the correct place now
Users browsing this forum: No registered users and 337 guests
