Possible bush replacement
STURS4
Post by STURS4 » Tue Jan 01, 2013 11:05 pm
Hey,
My rs4 is starting to feel a bit loose handling wise.There's a bit of a knock coming from the front when going over speed bumps,the car feels like its getting pulled left and right on certain surfaces and just generally not as taught as it was when i bought it 6 or so months ago.the car has done 67K so im thinking there maybe a few bushes due for replacement.anyone had any similar issues?
cheers
Dal
Re: Possible bush replacement
Post by Dal » Tue Jan 01, 2013 11:25 pm
Replaced all my front arms about a month ago, well worth it like a new car again...
B8 RS4 in the fastest colour :smile_smoking:
zed_hn
Post by zed_hn » Wed Jan 02, 2013 2:51 am
Iv just changed my lower front rear arm and the front top and and rear top arm on both sides and the car is amazing wow!!! Well worth doing it, if u want some part numbers let us know
adsgreen
Post by adsgreen » Wed Jan 02, 2013 9:29 am
Also worth checking the steering rack bolt under the secondary ecu.
Same symptoms (knocking, but vague)
toyneg
Post by toyneg » Wed Jan 02, 2013 11:07 am
had all my bushes replaced in November and made a hell of a difference to the feel of the car.
Post by MikeFish » Wed Jan 02, 2013 12:00 pm
Is this a relatively simple job or best left to the experts?
ROY
Post by ROY » Thu Jan 03, 2013 1:15 am
Hi Zed
Good service by Lemforder - German precision timing.
So glad they landed with you before Xmas to get you back on the road.
Think Zed said he changed his without removing the suspension leg
Gone but not forgotten boohoo !!!
RS4 Sprint Blue Avant on Dyno after Carbon Clean http://youtu.be/7lsBbmmaDQc
zed_hn
Post by zed_hn » Thu Jan 03, 2013 1:51 am
Hi mike/Roy
They are easy enough to replace the only thing you have to ensure is getting a good alignment after, I used AMD technik in Essex to do the work and they used the hunter alignment system which is amazing, the car feels so tight after the change!! as for the parts I have to thank ROY who ordered the parts for me from Germany which are the lemforder ones OEM without the Audi rings on it, they are quality parts!!! All together including the fittings and the alignment it cost me near enough £500, £220 for the top arms £130 for the lower arms which are Audi ones that I picked up on ebay from parts depot and around the £250 mark for the work carried out by AMD technik and a few other bits done aswell.
Speak to BEN at AMD who will guide you through the in's and outs
Once again thanks ROY much appreciated for your help
STURS4
Post by STURS4 » Thu Jan 03, 2013 8:16 pm
Thanks for the info guys.ive had it to the garage today and seen what the priblem is.both front and rear arms need replacing.they are warn and have been contacting each other.+ 4 new tyres,expensive visit to the doctors.
klauster
Post by klauster » Fri Jan 04, 2013 10:18 am
STURS4 wrote:Thanks for the info guys.ive had it to the garage today and seen what the priblem is.both front and rear arms need replacing.they are warn and have been contacting each other.+ 4 new tyres,expensive visit to the doctors.
How much is it for the new arms? I'd be up for a group buy on these....
Spaceman_RS4
Post by Spaceman_RS4 » Fri Jan 04, 2013 10:39 am
I'd be up for a group buy on a complete kit of arms and bolts needed too don't fell I need them yet but would buy for. When I do.
Ordered b9 S4 Avant ibis white
Panther black 8V RS3
Misano Red B7 RS4 Saloon
STURS4
Post by STURS4 » Fri Jan 04, 2013 12:35 pm
I will double check later,think it going to come to just under £400 for the lot
adsgreen
Post by adsgreen » Fri Jan 04, 2013 12:37 pm
I still can't believe that this topic with it's title the way it is has gone on for so long without any sniggering ;)
zed_hn
Post by zed_hn » Fri Jan 04, 2013 1:04 pm
Lads check on ebay genuine Audi lower front rear arms are going for £60 and the top arms are £200 from lemforder,
spikeyboy101
Post by spikeyboy101 » Fri Jan 04, 2013 2:34 pm
Can you link to them as im buggered if i can find on ebay.
Users browsing this forum: No registered users and 337 guests
