Long Life Service
Long Life Service
My RS4 is on the Long Life Service plan - last serviced 21/02/12 @ 55545 miles by the previous owner at Watford Audi. It's now on 58900 miles and I checked the oil at the weekend and it is on/slightly below minimum. Looking at the service record, the 'Oil Change' box is checked as 'No' but as part of the long life service it should be changed?
I called Watford Audi who said I should call Audi UK, who called WA on my behalf. They said oil was changed as part of the lls but they don't check as Yes? Seems a bit weird to me.
So question is, should I use that much oil in 3500 miles? Do I have to use the Audi recommended oil for long life service oil to top it up with?
Re: Long Life Service
Im sure Audi will say that around 1 litre used in 3500 miles is "within tolerance".
- MartayMcFly
- 5th Gear
1l per 1000 miles is normal, but some cars might be worse than that. Shouldn't go from full to below Min in just 3500 miles though. Have you checked for leaks?
edit - actually, anyone know the volume difference between Min and Max on these cars? Maybe it is around 4l.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
1litre in 3.5k is perfectly normal
top it up and carry on with life
I've had exact same query on a LLS check sheet, and yes, that's apparently just the way they record itGLOL wrote:They said oil was changed as part of the lls but they don't check as Yes? Seems a bit weird to me.
As D_K says - nout to worry about. I just got myself a 1l top up bottle and keep it in the boot for peace of mind in case the light comes on when I'm on a long journey (plus a 4l in the shed to top up the 1l with)
I understand your point, I thought the same initialy, but as far as I can remember there are 3 types of service you can have on your car; longlife, oil change and full service (can't remember if that is the proper name for it).GLOL wrote:
...the 'Oil Change' box is checked as 'No' but as part of the long life service it should be changed?
All 3 of them include an oil change.
If they ticked longlife and oil change they are implying that you have had 2 different types of service done and is almost contradictory; if I saw both ticked I would then ask the question 'which service did you carry out? The Oil Change or Longlife?'
So they are right to only tick the longlife box.
Plus one of these little fellas for clean oil top ups http://www.amazon.co.uk/Kitchen-Craft-C ... 589&sr=8-3 - very handy given that the card funnel that you get with a 1l bottle has to go in the bin after 1 use!MikeFish wrote:Same here.DALO wrote:
spikeyboy101
1ltr in boot and 4ltrs in garage.
Im using about 1 ltr per 2,000 Miles.
When on the lowest marking i fill with 1 ltr that takes it to the top marking.
Never worry about funells - just aim carefully and fill her up
i had the same question. thanks everybody for clearing that up!
what oil do they use? is that the same for every dealer, or could that be different per dealer?
am i correct in saying Castrol Edge full synthetic? but which viscosity?
thanks
robert
thanks
robert
B7 RS4 avant misano red
Black optics rpsxr style
- MartayMcFly
- 5th Gear
5W-30, Robert. Head out to Costco and pick up 4l for £24 + tax (was 20% off, but that ended yesterday).
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
i was there, but didn't know which one to take...
that's why the question.
but i'll be back soon! (Schwarzenegger?!?)
cheers
robert
cheers
robert
Castrol Edge 5w 30 IIRC...
Correct.DALO wrote:Castrol Edge 5w 30 IIRC...
Nice. Just ordered the green one.DALO wrote: [...]
p.s. FWIW I always end up getting my oil from ASDA. Collecting from the local supermarket is handy and I keep missing the Costco deals.
Users browsing this forum: No registered users and 415 guests
