Bluetooth
dan101smith
Bluetooth
Post by dan101smith » Fri Nov 23, 2012 10:33 am
Right chaps, the time has come. I need to find a suitable solution to add Bluetooth to my S4.
It's an '04 with RNS-E and Bose.
I'd also really like to add iPod control. So, the Parrot MKi9200 looks like it ticks all the boxes. Is there a better solution than this?
ASC
Re: Bluetooth
Post by ASC » Fri Nov 23, 2012 11:47 am
I had one fitted to my last car, B7 A4 special edition with Bose. All phone functions were fine and nice to use. But a couple of things annoyed me about Ipod connection/sound. Firstly it needs an extra loom at £35 (Ok no big deal) for the Bose amp. Another niggle was I couldn't control fade with it like you can listening to a CD or radio. There are a couple of dip switches you can play with on the black box behind the dash but could never get it sounding how I wanted it.. It also went through 2 control pads and 2 screens, (just died for no reason) all changed under warranty but could've been expensive out of warranty.
They seem to get good reviews though so maybe I was just unlucky or bad install maybe!?
I still have it, just not got round to fitting it to the S4 yet..
Current - 07 Sprint Blue RS4 Avant Black optics / Buckets / FBSW / MRC Stage 2 / De flapped Manifold / CAF / BMC filter / Decat / Non Res Miltek / Bilstein B16's / Tarox discs, pads and lines / H&R ARBs / 19x9.5 Ispiri ISR1 wheels / MPSS tyres / DTM carbon splitter
Previous - 06 Sprint Blue B7 S4 Avant JHM 91 tune / 2.5" Custom Cat-less DP's / Miltek Non Res Cat back / BMC filter / H&R springs / 19" Fox MS007 wheels/Good Year F1's / EBC TG discs / Yellow stuff pads
dan101smith
Re: Bluetooth
Post by dan101smith » Fri Nov 23, 2012 4:33 pm
You mean fade front to rear? Isn't that because it only plays through the front speakers?
MaLicE
Re: Bluetooth
Post by MaLicE » Fri Nov 23, 2012 4:53 pm
It doesn't play in stereo.... You are better off buying the audi genuine Bluetooth unit and doing a retrofit on it... Then a separate iPod unit...
Or you could go for the fiscon unit which allows A2DP which means you can stream music from iphone/iPod over Bluetooth...
http://www.fiscon-mobile.eu/products/rns_e.php
Similar price to the audi unit and does everything the same, so displays in the dis and you can use multifunction steering wheel and control it all through the rnse....
ASC
Re: Bluetooth
Post by ASC » Sat Nov 24, 2012 9:55 am
dan101smith wrote:You mean fade front to rear? Isn't that because it only plays through the front speakers?
It plays through the rears as well but you can hardly hear it. The dip switches control balance and fade but it's not great..
I'll probably put it back in the S4 for the phone but will definitely be looking for something else for the ipod. I'll look into the Audi unit, thanks MaLice.
MaLicE
Re: Bluetooth
Post by MaLicE » Sun Nov 25, 2012 7:17 pm
The ideal settup would be
Mrk2 rnse
Audi ami in glove box for the iPod (you can control the iPod or iphone through the rnse properly with track listings etc)
Audi Bluetooth unit
However if you don't fancy spending a huge amount, the rnse mrk1 with the fiscon unit will allow you to use Bluetooth and control iphone through the unit and it integrates to the unit just like the audi unit does....
spikeyboy101
Re: Bluetooth
Post by spikeyboy101 » Wed Nov 28, 2012 11:21 pm
Mki9200 works great with both runs-d and runs-e
You just need to find an installer that knows what they are doing and which loom to use so that you go in in pre Bose amps - then it sounds great and you still get stereo and all audio control.
There is a thread in the rs4 section on this
Users browsing this forum: No registered users and 52 guests
