How long should brake disks last?
klauster
Post by klauster » Tue Nov 20, 2012 6:09 pm
What mileage would you expect to get out of brake disks?
wrekka
Re: How long should brake disks last?
Post by wrekka » Tue Nov 20, 2012 6:15 pm
You've not worn out the discs that you got through the deal you organized have you nick?
TTS RS4 -amazing machine,
Previous:
Post by MikeFish » Tue Nov 20, 2012 6:23 pm
From my experience its 2 sets of pads, about 40-50k.
PetrolDave
Post by PetrolDave » Tue Nov 20, 2012 6:36 pm
MikeFish wrote:From my experience its 2 sets of pads, about 40-50k.
+1
Exactly the same for me.
ArthurPE
Post by ArthurPE » Tue Nov 20, 2012 11:12 pm
I have 75k on mine and they are 60% or so worn now
I recently mic'ed them, at 70k or so
no cracks at the holes
I change pads every 30k or so, on the 3rd or 4th set
JackS4
Post by JackS4 » Wed Nov 21, 2012 9:46 am
My experience is slightly different, I have averaged about 20k per set of discs and am on my third set of fronts at 53k. The discs have always gone long before the pads have though I am still on my original discs and pads on the rear.
I do quite a bit of urban drving which is all I can put the shorter life down to based on the mileage everyone else seems to get.
J
Post by MikeFish » Wed Nov 21, 2012 10:25 am
Dude there's something wrong with your driving / the car if you pads out live your discs! Don't kid yourself its the urban driving either, I used to drive mine in central London everyday when I still lived in London so rarely saw an open road and I am heavy footed.
klauster
Post by klauster » Wed Nov 21, 2012 10:40 am
I thought it was good practice to replace the pads when you change the disks?
JackS4
Post by JackS4 » Wed Nov 21, 2012 10:54 am
It is and I changed the front pads each time the dics where changed. FWIW, the pads generally had a third left in them when the discs where changed.
J
Post by MikeFish » Wed Nov 21, 2012 11:24 am
klauster wrote:I thought it was good practice to replace the pads when you change the disks?
It is, but it is not normal to wear out a set of disks by using 2 thirds of a set of pads, unless you use metal files for pads!
Normally you'd get a through a couple of sets of pads before you need to change the disks.
Post by MikeFish » Wed Nov 21, 2012 11:27 am
JackS4 wrote:It is and I changed the front pads each time the dics where changed. FWIW, the pads generally had a third left in them when the discs where changed.
J
What made you think that the disks needed changing after just 2 thirds of a pads useage? Do you keep warping them or are you wearing them down? I find it hard if not impossible to believe that you can wear a disk down with less than one set of pads. Did you measure the disk thickness?
Are you using standard disks? and what pads?
JackS4
Post by JackS4 » Wed Nov 21, 2012 11:40 am
Discs/pads all OE no warping. Audi advised change required due to wear which I usually ignore for 6/9 months by which time there is a huge lip on the outside of the discs and they look like the have been monstered on trackdays even though I don't track the car. Last worn set had visible dash-lined 'spokes' from the centre to outer part of the discs that kind of looked like lines of little cracks but where not.
J
Post by MikeFish » Wed Nov 21, 2012 11:50 am
I'd be tempted to get a 2nd opinion next time or get yourself some calipers (the measuring type not the braking type) and meausre the thickness yourself.
if you ignore for 6/9 months and still not get through 2/3 of a set of pads then I can only assume you must do very low milage. How old are the disks when they recommend you change them? Perhaps it is ibecause they have corroded / perished rather than worn.
JackS4
Post by JackS4 » Wed Nov 21, 2012 12:23 pm
Discs where 2.5 years at the last change, to be fair they looked fooked.
J
lengster1
Post by lengster1 » Wed Nov 21, 2012 1:04 pm
Audi discs are renowned for being made of cheese,one set of pads will easily do one set of discs.Some have done discs in 15k.
Users browsing this forum: No registered users and 376 guests
