So, which ones actually work? One of mine has gone and it's a standard bulb jobby and I want to replace them for LEDs to better match the xenons.
Which ones work and will not get errors?
Thanks!
Sidelight bulbs, LED which ones work
randomshenans
- 1st Gear
Re: Sidelight bulbs, LED which ones work
The thread you need. Please don't make the same mistake other have though - B6 and B7 headlights are different....
For the record the original pair I put in two years ago are still going strong, and they match the xenons perfectly
http://forum.rs246.com/viewtopic.php?f=28&t=78232
- cobraBLACK
Audi S4 Avant (B6, 2004) in Goodwood Green.
There was a spare bulb in the glovebox as i had one go and bought 2
you dont have to go for LEDs.. a lot of these either need resistors or throw an error-code
i got white sidelights and DRL PIAA bulbs from Glen @ Revolution Motorstore.. think i paid £23 for the DRLs and £15 for the sides
all good so far - and great delivery time/service
goose
goose
Current:
'08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
'72 Sunburst Yellow VW Karmann Ghia Coupe|1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 interior
Past:
'06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
Past:
randomshenans
- 1st Gear
Mine sometimes error. When I either boot the <beep> out of it, corner a little hard or lamp on the brakes. Connections all seem tight though. I just live with it. They still work 99% of the time.
