Can't wait for Ian to finish baking my XP10 front pads!
Ryan_Pestell
Re: Can't wait for Ian to finish baking my XP10 front pads!
to be fair even my mintex/or ebc yellow's at the rear of mine squeal when cold and that bugs the <beep> out of me, and they are crap for the first few stops, will there is atleast some heat in them.
Daytona RS6+ Sold
Now Building a 500HP Lotus Exige
- Mr Footlong
The pads bite brilliantly, even when cold within reason. The squeel is there regardless of whether they are hot or cold. In actual fact, they squeel far less from cold but as soon as they start getting warm the noise ramps up accordingly at low speed.
Current:
Gone:
Gone:
Ryan_Pestell
yeah DS3000 do that aswell, i guess anything with a high metallic content like you have experienced, will squel and eat discs, mintex 3000 go through discs like a hot knife through butter.
Daytona RS6+ Sold
Feeling good about my C6 brakes now.
- Mr Footlong
Ben
I love you but shut up
. No spacers, no joy
Current:
Gone:
Gone:
Many many coupe owners suffer the same fate of squeeking brakes and they have tried every pad on the market. It must also be down to the pad fitting in the caliper (brembos on the 20vt also). Varioous people - including me - have tried backing plates on the pads and that sometimes solves it. In the end I fitted different brakes anyway.
I'm not that bothered though. You never see a racing car without squeeling brakes
Daytona RS6 Avant
Can the ET be modified on alloys? Machine a bit off the inner flange of the rim? Just wondering.
Ryan_Pestell
It can be within reason and dependant of the mounting face.
i've shaved 12mm off some BBS wheels before.
Daytona RS6+ Sold
^^ yum
If you could shave 7mm then you could run the C6 setup. Or even 5mm, 1mm of the disk bell surface and have your wheel stick out 1mm... just a thought.
I looked into this instead of rolling the arches, it's not uncommon, you can take some off the bell and some off the back of the wheel BUT I wasn't keen because it'll effect resale of wheels, IMO.Shoppinit wrote:If you could shave 7mm then you could run the C6 setup. Or even 5mm, 1mm of the disk bell surface and have your wheel stick out 1mm... just a thought.
Superglue some spacers on when you sell the wheels. Job done.
...and you'd still want first dibs on my HREs when I sell?Shoppinit wrote:Superglue some spacers on when you sell the wheels. Job done.
/EDIT you have C6 stoppers, so, yeah, you probably would...
That'll make them virtually unsellable to anyone but me. Get skimming
- Mr Footlong
The problem with all that is that I would have to find somewhere up to the task, then they would probably need the ryres removed, I would then be unlucky and get another set of heary-handed idiot that then scratch up the rims to buggery either removing or refitting the tyres. I am totally fine with modifying the actual rims, but the chances are that someone could balls up the tyre removal makes me grimace.
Current:
Gone:
Gone:
Users browsing this forum: No registered users and 221 guests
