got bored today...
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
imolas4uk
Post by imolas4uk » Sat Mar 15, 2008 12:26 am
looking nice,whats the front number plate ?,is that painted directly onto the intercooler ?,looks good 8)
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
quattronutter
Post by quattronutter » Sat Mar 15, 2008 12:37 am
its my home made quick release vented number plate,i was going to paint onto the intercooler but you wouldnt be able to see the plate properly probably no bad thing thoug:wink: keeps it looking a bit sleeper ish...
g60bv
Post by g60bv » Sat Mar 15, 2008 9:31 am
:notworthy:
i salute you sir.
:jump_clap:
well done. this has been an excellent read. and should help fellow s4 owners to be able, one day, to attempt this on their own.
i wounder if we could make a locked thread with all your photos in as a kind of step by step guide.
seeing the ups and downs of it all.
you must report on power delivery, overall smoothness and mpg. power will be mentioned of course.
would be interesting what components you used. rods and pistons. where and dimentions. ( std or bigger) did you use any rs4 bits.? crank bearings oil pump etc.
well done that man.
:bowdown: :bowdown: :bowdown:
ian.
MRC TUNED 480BHP . -SOLD 1.9TDI AVANT 215HP. HYDBRID TURBO. SMOKING
quattronutter
Post by quattronutter » Sat Mar 15, 2008 7:21 pm
the engine has the following spec,s4 block,rods from dahlback,standard pistons,low comp head gaskets,standard s4 heads with ported/welded manifolds,raceware head studs,rs4/6 hybrid turbos,millitek downpipes with the cats removed,custom fmic,mrc intake pipes,rs4 maf and y pipe,lower rs4 airbox,apr bi pipe,600cc injectors,10 bar fuel pump,water/methanol injection,200bhp shot of nitrous,replaced the gearbox too for a very low mileage one also rs4 clutch which should last at least 5 mins...i still have a very slightly lumpy idle which it had before,no air leaks either only a faulty boost valve which i will fix before the map gets tweaked,also has vag com running permanently through the kenwood head unit 8)
g60bv
Post by g60bv » Sun Mar 16, 2008 9:14 am
how have you got vag com through the head unit, that sounds mint.!
S4TAN
Post by S4TAN » Sun Mar 16, 2008 9:42 am
Nice pics - you have excellent taste in wheels!
Deus ex machina
quattronutter
Post by quattronutter » Sun Mar 16, 2008 11:29 am
S4TAN wrote:Nice pics - you have excellent taste in wheels!
just need to paint them in gun metal make them look a bit harder..
quattronutter
Post by quattronutter » Sun Mar 16, 2008 11:31 am
g60bv wrote:how have you got vag com through the head unit, that sounds mint.!
mini pc in boot running into kenwood system
S4TAN
Post by S4TAN » Sun Mar 16, 2008 11:50 am
Yep - mine will be getting painted smoked-silver/gunmetal at some point soon ...
18's or 19's?
Deus ex machina
Ads4
Post by Ads4 » Sun Mar 16, 2008 11:59 am
Should look good Jules....big fan of gunmetal wheels on silver :thumbs:
Adam.
MRC B5 S4 Avant.
MarkB
Post by MarkB » Sun Mar 16, 2008 12:01 pm
quattronutter wrote:its my own homebrewed fmic,pipework made up from 2in stainless also has a shrouding which you cant see in the pics,stops any air escaping round the sides of the intercooler,every little bit helps...
I could live with a front mount cooler as neat as that.
How much would it cost to build another setup the same?
Mark
S4TAN
Post by S4TAN » Sun Mar 16, 2008 12:04 pm
Yep - I reckon so. :thumb:
2nd that.
Deus ex machina
mikeyquattro
Post by mikeyquattro » Sun Mar 16, 2008 12:09 pm
18's or 19's?
Thought they already were, or is that just cos you're toooo lazy to wash 'em?
Tomorrow is another day
S4TAN
Post by S4TAN » Sun Mar 16, 2008 12:10 pm
Too lazy! :nodder:
Deus ex machina
quattronutter
Post by quattronutter » Sun Mar 16, 2008 12:59 pm
i can make up the whole lot again for about 600 quid
