Rolling Road Day at QST
martins3
Post by martins3 » Mon Dec 06, 2004 8:56 pm
Hi, it is good that kim will run the S3's and TT's in 4x4 mode because I emailed Haldex about it and they said only run in 2wd mode if the prop shaft is removed because there could still be a drive through the rear diff because of the oil drag when the car is flat out on the rollers at about 100mph+, can you put me down please, Cheers Martin
Wak
Post by Wak » Mon Dec 06, 2004 9:16 pm
I'll be in if its 4wd.... :)
but dont wait for me, I need a late slot as I'll be driving down from Bedford so I'll come down by 11.30-Midday hopefully.
Scotty
Post by Scotty » Mon Dec 06, 2004 9:23 pm
Count me in. As early as possible for me.
B8 A4 Avant quattro
Suzuki GSXR1000 (Track bike)
B6 S4 (AMD Stage 3) - GONE
8N TT (APR/AMD/MTM) - GONE
johneroberts
Post by johneroberts » Mon Dec 06, 2004 10:51 pm
Looks quite a successful day in the making guys, hope you all have fun...
Oh and someone tell Kim to lighten up
That boys running on the edge at present
jr
Driving is believing
RS246 Founder
clived
Post by clived » Mon Dec 06, 2004 10:58 pm
martins3 wrote:Hi, it is good that kim will run the S3's and TT's in 4x4 mode because I emailed Haldex about it and they said only run in 2wd mode if the prop shaft is removed because there could still be a drive through the rear diff because of the oil drag when the car is flat out on the rollers at about 100mph+, can you put me down please, Cheers Martin
Surely that would only be an issue if the rear wheels were prevented from rotating. I'd always assumed that on a 4WD RR the rear rollers were just in "free rotate" mode if it's running 2WD.... but I don't know. Does anyone know for sure?
Cheers, Clive
martins3
Post by martins3 » Tue Dec 07, 2004 1:30 am
Cheers, Clive
I don't know if they run with the rear rollers running free but if Haldex themselves say don't try it without removing the prop shaft I wouldn't try it on my car, I spoke to Mike at Jabba Sport about it before and when they tried there 4x4 scoda on there rollers in 2wd mode they measured a higher drag through the transmition than running in 4wd mode, this must be the drag in the Haldex diff oil, Haldex said in there email to me you can get over 7ibft of torque transfer through the diff when the fuse is out running in 2wd mode through the oil drag and more at speed when the car is on the rollers at 100mph+
martins3
HOW THE HALDEX UNIT WORKS
Post by martins3 » Tue Dec 07, 2004 1:47 am
HOW THE HALDEX WORKS
The design of the Haldex LSC is based on a Swedish patent acquired by the Haldex Group.
The unique design of the Haldex LSC comprises three functional parts
- The hydraulic pump driven by
- the slip between the
- axles/wheels.
- The wet multi-plate clutch
- The controllable throttle valve
- with its electronics.
The unit can be viewed as a hydraulic pump in which the housing and an annular piston are connected to one shaft and a piston actuator is connected to the other.
The two shafts are connected via the wet multi-plate clutch pack, normally unloaded and thus transferring no torque between the shafts.
When both shafts are rotating at the same speed, there is no pumping action. When a speed difference occurs, the pumping starts immediately to generate oil flow. It is a piston pump, so there is a virtually instant reaction with no low-speed pumping loss.
The oil flows to a clutch piston, compressing the clutch pack and braking the speed difference between the axles. The oil returns to the reservoir via a controllable valve, which adjusts the oil pressure and the force on the clutch package.
In traction/high slip conditions, a high pressure is delivered: in tight curves (i.e. parking), or at high speeds - a much lower pressure is provided
clived
Post by clived » Tue Dec 07, 2004 7:46 am
Martin, I *think* that what Haldex are saying is "don't run with the fuse out with the rear wheels unable to turn, or else that torque has no-where to go and will heat up the Haldex". Be interestesting to know if the rear wheels are free to / do turn with the fuse pulled!
Clive
B7 S4 Cab
B5 RS4: MRC custom remap, Milltek 100cpi cats and rear system, RS6 8-pots, H&R PCS coilovers, H&R ARBs, AWE DTS, Tanoga Shortshift, Dynaudio / Focal / Genesis / iPod audio: SOLD, and still missed. One day....
UK225
Post by UK225 » Tue Dec 07, 2004 12:00 pm
Hi Guys,
Unfortunately I am now having to work very late on Friday night, I will still try & make this now the haldex can run 4wd but I am not 100% going to definatley attend & wont be there first thing if I do.
Morgan
Prawn
Post by Prawn » Tue Dec 07, 2004 2:44 pm
So confirmed so far :
ChrisG - Early Slot
Scotty - Early Slot
Simonelman
DuncS3
sitas3
bjacks
Prawn
MartinS3
JohnRS4
Wak - Late Slot
UK225 - Possible
S4Driver and JeffW - waiting confirmation
See you all Saturday.
Prawn
jeffw
Post by jeffw » Tue Dec 07, 2004 4:40 pm
Confirmation of what ? I said I'd be there....In fact my car is at QST on the Friday for it's 80K service.
Prawn
Post by Prawn » Tue Dec 07, 2004 6:12 pm
ChrisG - Early Slot
Scotty - Early Slot
Simonelman
DuncS3
sitas3
bjacks
Prawn
MartinS3
JohnRS4
JeffW - :thumbs:
Wak - Late Slot
UK225 - Possible
S4Driver - waiting confirmation
Prawn
S4driver
Post by S4driver » Tue Dec 07, 2004 7:43 pm
You called :wink:
I shall be there Saturday. Is it possible i will be able to have an early'ish slot for a power run? May have to get back to work early afternoon.....
Also, does anyone who is going have VAGcom? Maybe someone could see if something shows up regarding my alarm........
Prawn
Post by Prawn » Tue Dec 07, 2004 8:15 pm
ChrisG - Early Slot
Scotty - Early Slot
S4river - Early Slot
Simonelman
DuncS3
sitas3
bjacks
Prawn
MartinS3
JohnRS4
JeffW -
Wak - Late Slot
UK225 - Possible
I will take my laptop ang VAGcom down with me.
Prawn
jeffw
Post by jeffw » Tue Dec 07, 2004 8:30 pm
Who is going to have most on the day....????
Users browsing this forum: No registered users and 164 guests
