Engine / Gearbox Removal
5.0 V10 50v biturbo - 571 bhp
c3nturi0n
Re: Engine / Gearbox Removal
Post by c3nturi0n » Mon Feb 24, 2020 11:41 pm
Jim Haseltine wrote:
Mon Feb 24, 2020 7:05 pm
How long? Awkward question. There are a number of factors to take into account, not the least being that I was taking my time, was working outside with little space and the car on stands. I have about 3' between the front of the car and a wall, similar distance behind it to another wall and the same (at best) to the right where there's another car. It's only to the left of the car where I've got unrestricted access. Lifting gear was a decent trolley jack (3 ton I think) and an engine crane. I also had to knock off from time to time so I could source tools which I didn't have. And then there were things like having to cut off the exhaust sleeves and dealing with a difficult positioned bolt that I'd stripped. Ignoring breaks and other times when I wasn't actually working (neighbours do insist on talking) I'd say it was over 30 hours spread over a week and a half, maybe two, to get the engine out. Working inside with space to move, a post lift, all the tools to hand, an assistant when needed AND having done the job once already, I could take at least 10 hours off that, maybe even half it.
But that's taking it out and remember, although the engine was free, I never moved it away from the car, I just slid it back, lifted it and bolted the mounts into place after I'd taken the manifolds off then dropped it again later to refit them but I also removed other things (like the oil tank so it could be repainted) which don't need to be touched if you're just dropping the engine. Putting it all back in place properly took at least as long as taking it out - and that was before I got around to filling the fluids.
Cheers Jim.
Still contemplating on the idea is it worth doing this job or not!? :sleeping_2: :audibash: :sleeping_2:
Other than an oil seal, is it worth tackling other jobs when the engine is out?
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
Jim Haseltine
Post by Jim Haseltine » Tue Feb 25, 2020 12:09 am
You can always find other jobs to do when the engine is out - I did. I can't think of how many times I thought something along the lines of "Well, it'll be a while before I'm ready to put it together again so I may as well do...". Unconnected with the turbos and other work in the engine compartment, I've changed the rear discs & pads, fitted new bump stops on the rear shocks, poly bushed the roll bars & drop links and resprayed the cills and rear bumper. There's probably some other jobs that I've forgotten too.
welwynnick
Post by welwynnick » Sun May 31, 2020 10:05 am
Can anyone say whether it's feasible to remove the gearbox without removing the engine? I've done it a few times on other V8/12 cars, though obviously not an RS6.
Just wondering
Nick
C_J
Post by C_J » Sun May 31, 2020 10:31 am
I’ve never done it personally.
But I’ve seen it done on two occasions so yes it’s possible.
S4 b5 340bhp
Rs4 b5 507bhp
Rs6 c6 project 800bhp
S3 stock daily work hack
welwynnick
Post by welwynnick » Sun May 31, 2020 11:57 am
Thanks.
I think ATinOf also answered a lot of questions in his "Removing the Gearbox.." thread: viewtopic.php?f=47&t=129515
It sounds like the main issue was disconnecting the nearside downpipe.
Cheers, Nick
ruedisrs6
Post by ruedisrs6 » Mon Mar 18, 2024 9:15 pm
It seems that I will need to do the same procedure because of a substantial oil leak of the seal on the right front between the bedplate and the oil sump. When this engine gets old, it develops huge oil leak problems I never thought about in my life before with "normal" cars :cry:
I feel brave enough to do the job, the only issue is that I am not sure about the AC compressor. If I follow the descibed procedure here (I know this is not environmentally fully correct) and open the AC pressure line, can I - after reconnecting all AC lines and tubes to the compressor - start the engine and drive to a workshop to do the filling procedure ? I am asking this because the compressor does not have a magnetic clutch and is regulated by a valve via PWM, which does not go below 5%. Do I destroy the compressor by starting the engine while the AC system is empty ? I searched a lot about this issue and contacted Denso, however, no reply from them.
Many thanks, any feedback is most appreciated.
Best
Rudy
ATinOf
Post by ATinOf » Fri Apr 26, 2024 10:30 pm
There is a pressure switch in the system, if there is no pressure the AC will not be on, you will be fine running to the garage. You are correct you are not meant to 'vent' to atmosphere, and the longer the lines are left open the more moisture will be build up in the system, but the procedure accounts for that when its vacuumed out. If its open for a prolonged period consider replacing the dessicant. Recommend a proper refill though, not your halfords job with the pre oiled refill cans
Users browsing this forum: CupraDine and 68 guests
