Ceramics - front and rear?
Lasse
Re: Ceramics - front and rear?
Post by Lasse » Sun Jan 21, 2018 11:08 am
Regarding Ceramic front and rear.
I convert my RS4 from 2007 with Ceramic brakes on rear axle for some year ago. My car have Ceramic on front from new, but I didnt like the steel at rear end.
Use disc, braket and pads from RS6, C6. Small modify of the bracket, make a thin spacer between disc and hub, and Mill some mm from all 4 pads.
I use the RS4 standard calipers, so handbrake works like standard. Brake shield I dont remenber, but it was from some RS model.
Use my car daily, and 2-4 trackdays every year. It works without problem.
The only negative is brakepower is little to strong in rear end, you can feel it when braking from high speed.Image
Softishman
Post by Softishman » Sun Jan 21, 2018 9:08 pm
What size is rear disc? I am converting to RS6/rs7 370mm cermaic rear with separate handbrake caliper and custom brackets.
@softishman on IG
Check out my RS4 there!
Lasse
Post by Lasse » Mon Jan 22, 2018 5:27 pm
Hi. Not sure, but can it be 356mm?
//Lasse
Softishman
Post by Softishman » Wed Jan 24, 2018 12:35 pm
Were in Sweden do you live Lasse? Is the discs from an R8 then?
@softishman on IG
Lasse
Post by Lasse » Wed Jan 24, 2018 6:00 pm
Hi. I think I bought RS6, but the discs are probably the same on RS6, R8 and VW Phantom? I can check the number on the discs during the weekend. On the brake caliper that follow with it's a electric handbrake, therefore I used the RS4-B7 caliper.
I lives in Arvika.
//Lasse
Softishman
Post by Softishman » Wed Jan 24, 2018 6:19 pm
Depends on what year they are from. RS6/RS7 have 370mm rear disc, that is what i use. Then i just unbolted the eletric motor for the handbrake, bought separate handbrake calipers and had a custom bracket made for this.
Do you have Instagram lasse?
@softishman on IG
Surrey Sam
Post by Surrey Sam » Wed Jan 24, 2018 6:36 pm
Softishman, do you know if the rear disc offset is different between S6/RS6 and S7/RS7?
Softishman
Post by Softishman » Wed Jan 24, 2018 8:23 pm
Audi S6 ans S7 uses the same disc, the RS6/RS7 uses another disc, don’t know the difference more the they have another part nr.
4H0615601G Rear left brake disc 36546:- SEK replaced with 601R or 602J
4H0615602C Rear right brak disc 36546:- SEK
Fits Audi A6/S6 2011 ->, Audi A7/S7 2011 -> and Audi A8/S8 2010 ->
4G0615403B Caliper rear left 7191:-SEK
4G0615404B Caliper rear right 7191:- SEK
Fits A6/S6 2011-2014, A7/S7 2011-2014,RS6 2013-> and RS7 2014->
4H0698451F rear brake pads 3291:- SEK
Caliper bracket 2106:-/st 4G0615425/6
Fits A6/S6 2011->, A7/S7 2011->, RS6 2013-> and RS7 2014->
Hope this info is usefull for someone?!
@softishman on IG
Softishman
Post by Softishman » Thu Mar 01, 2018 2:02 pm
Might have a front kit for RS4 B7 without pads for sale soon... Somebody intressted?
@softishman on IG
RS4LAD
Post by RS4LAD » Thu Mar 01, 2018 6:47 pm
YES!!!!!!!!
RS4LAD
Post by RS4LAD » Thu Mar 01, 2018 6:48 pm
Iv just pm’d you on insta mate
Softishman
Post by Softishman » Fri Mar 02, 2018 1:33 pm
James?! ;) Talk more there!
@softishman on IG
Users browsing this forum: No registered users and 119 guests
