Audi RS6 Performance C7
Re: Audi RS6 Performance C7
Post by MikeFish » Sun Jan 01, 2017 11:29 pm
Regarding the coilovers: Nice pervy attention to details that most people won't even notice!
Regarding the rear rings: I had mine removed by the dealer before I even picked the car up. I think it makes the rear look a bit cleaner along with the rear wiper removal.
Jack Falla
Post by Jack Falla » Mon Jan 02, 2017 12:10 am
MikeFish wrote:Regarding the coilovers: Nice pervy attention to details that most people won't even notice!
I am a bit anal like that. If I know it's there and I don't like it, it will bug me. He's even making me the bumpstops in black instead of that nasty orangey yellow.
I agree I do like the clean back end. I haven't removed my rear wiper. Did you remove the whole motor?
Lamborghini Squadra Corse
RDC Automotive Group Ltd
Lordes Luxury Car Storage
Lordes Detailing Devision
FEYNLAB CI
Cars & Coffee CI
Post by MikeFish » Mon Jan 02, 2017 12:16 am
Yep, arm off then removed the motor from the inside of the tailgate and blocked the washer hose. Then blocked the hole with a bung from killallwipers.
Post by MikeFish » Mon Jan 02, 2017 12:18 am
doodlebug
Post by doodlebug » Mon Jan 02, 2017 8:08 am
How the feck do you see out of the back in the current weather?!
Jack Falla
Post by Jack Falla » Mon Jan 02, 2017 10:53 am
It does look smart. How did you block the water hose? That would worry me.
FEYNLAB CI
Cars & Coffee CI
Post by MikeFish » Mon Jan 02, 2017 11:56 am
A.small screw/ nail in the end with a cable tie and then a bit of tape or self amalgamating tape is more than enough to block the hose.
And my car is washed nearly every week and it gets regular coatings of G technic glass protector / water repellent to help keep it clear. Failing that I have a rag and bottle of waterless wash in the boot just in case. Plus cameras and parking sensors.
Jack Falla
Post by Jack Falla » Wed Jan 04, 2017 10:53 pm
So the Milltek is on. After a very long wait the full non resonated cat back milltek system arrived this morning. I couldn't wait for the weekend though fit so I managed to convince my Audi technician friend that fitting it tonight was a good idea. Thankfully he agreed!
I could not believe the weight difference from the standard performance exhaust to the Milltek. The bore of the pipe is noticeably bigger and the noise is addictive!
Sorry can't seem to upload pictures at the moment!
FEYNLAB CI
Cars & Coffee CI
Jack Falla
Post by Jack Falla » Thu Jan 05, 2017 10:28 pm
FEYNLAB CI
Cars & Coffee CI
Jack Falla
Post by Jack Falla » Sat Jan 07, 2017 1:49 pm
Suspension set up all powder coated, painted and rebuilt. Fitting today!
FEYNLAB CI
Cars & Coffee CI
Jack Falla
Post by Jack Falla » Sat Jan 07, 2017 1:50 pm
Before!
FEYNLAB CI
Cars & Coffee CI
Jack Falla
Post by Jack Falla » Mon Jan 09, 2017 12:19 am
So this is the 6 on pretty much the highest setting on the Gepfeffert KW Coilovers. Will let it settle for a week and see where it's at. I think it will sit better with 265/30 tires instead of the 285/30.
FEYNLAB CI
Cars & Coffee CI
Post by MikeFish » Mon Jan 09, 2017 12:22 am
Nice work on the respray and looking good. I know it will be going lower! Do you know what size tyres Jason runs on his car? I imagine his is about as low as you can go static and that is where you will end up so maybe worth asking him what size he runs?
Jack Falla
Post by Jack Falla » Wed Jan 11, 2017 8:42 pm
MikeFish wrote:Nice work on the respray and looking good. I know it will be going lower! Do you know what size tyres Jason runs on his car? I imagine his is about as low as you can go static and that is where you will end up so maybe worth asking him what size he runs?
Jason is running 265/30s so I need the get some ordered. My tires have touched my inner arch in the front and taken some paint off. I had the same issue with the H&R 40mm springs.
Know anyone that wants some 285/30 Dunlops that's have done 1000 miles?
FEYNLAB CI
Cars & Coffee CI
Post by MikeFish » Wed Jan 11, 2017 9:31 pm
Mine also rubs with 40mm springs at the front. Never really noticed until I took the wheels off to fit the spacers. I also removed the little plastic arch clip at the top of the arch as that was sticking out further. I think Luke runs narrow tyres too for a bit more clearance.
I can feel my wheels slipping when on full lock in the cold so I know the yare not as meaty as they used to be (racked up about 12000 miles now) so I am probably not far off some new tyres (and have Dunlops from factory which seemed to be the least commonly ones used) but when they get replaced it'll be for some Michelins. Are you changing all 4 tyres or just the front? If only the front then keep then as spares for the rear. Failing that, stick an advert on here.
Return to “Readers' Rides”
Users browsing this forum: No registered users and 92 guests
