RNS-E AMI Upgrade
PetrolDave
Re: RNS-E AMI Upgrade
Post by PetrolDave » Tue Apr 01, 2014 5:43 pm
esp_mm-270 wrote:Also, near the start of this thread it was asked about the changing of the knobs from black to silver 2010+ ones. Was it not worth answering as they just pop off? I used 'some' force to lever them off but didn't wanna go to far as I don't know how they are attached.
Missed that, sorry :notworthy:
The large multifunction knob is just a pull off and swap job, but the small knob needs the faceplate removing to swap it over.
esp_mm-270
Post by esp_mm-270 » Tue Apr 01, 2014 6:16 pm
Cool. Glad I didn't try to force them off now :beerchug: :)
Billy
Post by Billy » Sat May 03, 2014 3:55 pm
Afternoon chaps
Run into a bit of a problem yesterday. Everything was working with the RNS-E and DIS, then started up in the afternoon and well....god knows what has happened.
First thing is the RNS-E is not coming on or going off with the ignition, it just stays on all the time unless I manually turn it off. But it has shut itself down randomly when driving a few times.
Secondly I'm getting no info on the DIS from the RNS-E, but navigation and the rest is working on the RNS-E and I'm getting the turn commands.
Thirdly the bluetooth won't connect to the RNS-E and the SDS isn't working at all.
I've checked in VCDS and all the coding is correct but I have these errors that keep coming back after clearing DTC's.
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 R HW: 8E0 920 981 R
Component: KOMBI+WFS 4 H14 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0023411
Shop #: WSC 00001 210 00672
VCID: 3C7C34957C644DFE87F-515A
2 Faults Found:
01304 - Radio
004 - No Signal/Communication
01303 - Telephone Transceiver (R36)
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023411
2 Faults Found:
01304 - Radio
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 B HW: 8P0 035 193 B
Component: RNS-E PU EU H06 0220
Revision: 0000012S Serial number: AUZBZ7L6100690
Coding: 0309727
Shop #: WSC 00000 000 00000
VCID: 2F6613D9BD12A66632D-5102
2 Faults Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 58
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
00857 - CD Changer Unit (R41)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Time Indication: 15
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309727
2 Faults Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 58
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Time Indication: 15
From looking online it's looks like it maybe be a fault with the CAN bus connections???
But really no idea how to fix it.
Any ideas?
PetrolDave
Post by PetrolDave » Sat May 03, 2014 4:00 pm
Billy wrote:From looking online it's looks like it maybe be a fault with the CAN bus connections???
Definitely looks like a CAN bus problem.
I'd try popping the fuse for the RNS-E and the BT module, it's not unknown for the BT module to lockup so it's worth power cycling it.
Billy
Post by Billy » Sat May 03, 2014 4:05 pm
Thanks for the quick reply Dave, I'll give that a try first then.
PetrolDave
Post by PetrolDave » Sat May 03, 2014 5:06 pm
Billy wrote:Thanks for the quick reply Dave, I'll give that a try first then.
OK, my replies will be a bit sporadic as I'm in the USA at the moment.
Billy
Post by Billy » Sat May 03, 2014 5:48 pm
No problem, appreciate the help.
Ok so I pulled some fuses, not 100% sure I did the correct ones as tbh I've never done them before.
I tried number 5, 15 and tried 39 as well, the fuses looked ok but didn't make a difference apart from having to reset the time/date.
Were these the correct numbers?
PetrolDave
Post by PetrolDave » Sun May 04, 2014 1:12 pm
Billy wrote:didn't make a difference apart from having to reset the time/date.
That's strange, if the CAN connections are faulty then the RNS-E won't read the time from the instruments but it should set its time from the GPS.
Looks like you're gonna have to take a look at the connections maybe. Best plan is to disconnect one device at a time - I'd suggest in the order BT, AMI, RNS-E and check with VCDS when connections to the others start working again.
The BT module is still my #1 suspect, is yours factory or retrofit? If it's retrofit then its most likely behind the glovebox which will be easy to disconnect.
Billy
Post by Billy » Sun May 04, 2014 2:12 pm
Sorry, yes the RNS-E time didn't need resetting just the instruments.
I left the fuses out for 13-14 hours but still the same.
I then plugged in my old RNS-E so it was just this and the BT module and still exactly the same.
So yes looking like the BT module, it was retrofitted by pippyrips the previous owner, pretty sure he put it behind the glovebox.
I had look at the wiring with RNS-E out and noticed this wire not connected to anything. Looks like it comes from the BT module and the SDS button on the dash.
Could this be the issue maybe and if so any idea where it should be connected?
PetrolDave
Post by PetrolDave » Sun May 04, 2014 2:46 pm
Billy wrote:I had look at the wiring with RNS-E out and noticed this wire not connected to anything. Looks like it comes from the BT module and the SDS button on the dash.
Need to know what terminals that wire is connected to before I can comment - wire colours mean nothing.
Only thought is did pippyrips used to have a CANGate - as the SDS button would need to connect to that for it to function.
Billy
Post by Billy » Sun May 04, 2014 3:46 pm
I'm just guessing but I'm sure he did as like you say it wouldn't have worked otherwise.
I think I'm going to have to get someone to have a look at it, unplugging and plugging in I can just about manage, but terminals and wiring I've not a clue!
Appreciate your help Dave. Hope your enjoying the good old US of A!
J130YCE
Post by J130YCE » Thu Feb 05, 2015 9:31 pm
A
BMW M2 Comp
RS4 Supercharged
Current Abarth 500c Two tone Grey and Mint - a modified go-cart.
Current T5 180 bi-turbo - modified, Reimo pop top, ABT kit, Caravelle 7 seats, going on 'air' this summer
Gone RS4 B7 Avant MRC, MK5 R32, 205 GTI, Mk1 golfs... plus some other poor souls
RossDagley
Post by RossDagley » Fri Feb 06, 2015 3:33 pm
J130YCE wrote:A
Erm?
Previously:
irn_bru_ce
Post by irn_bru_ce » Tue Mar 31, 2015 6:51 pm
Great thread about recent information about RNS upgrades
Looking at the availble units, the eat Exeo would seem the simplest as its got the correct fascias, and doens't look like has Seat printed on the unit, just on the start up screen
Would it just be a plug and play to swap this unit into my RS4, currently got the CD changer and the TV tuner setup with originl unit, i have a ross-tech to do any coding
http://www.ebay.co.uk/itm/SEAT-RNS-E-EX ... 4192f14151
Current - 07 Avus Silver B7 RS4 Avant : Ceramics, Non Valved Non Res Milltek, K&N filter, SS+, adaptive xenons, black optics, KW3, 034 rear ARB, rear drop links & front adjustable top arms.
Past - 00 Saxo VTS : 266mm Mi16 calipers, Quaife ATB, 20mm torsions bars, 24mm ARB, Vibratechnics mounts
87 Vauxhall Belmont: 1.6L, 15" rockford fosgate subwoofer in 3 cuft sealed box, 5ch Rockford fosate amp, JBL components
Post by HYFR » Tue Mar 31, 2015 7:05 pm
I've got the Exeo unit fit
I got Hazzy Dayz to fit it along with AMI
Users browsing this forum: Bing [Bot] and 2727 guests
