B8 RS4 and engine carbon issues
4.2 V8 32v FSI - 444 bhp
doodlebug
Re: B8 RS4 and engine carbon issues
Post by doodlebug » Mon Mar 25, 2013 9:41 am
Aye, the new ZF 8 speed jobby has seen wide acclaim, no surprise it has found it's way into a wide range of cars.
No doubt lighter and less complex. Agreed, could be the way forward for the mass market. It will also help that the R&D feedback is coming from such a wide range of manufacturers.
adsgreen
Post by adsgreen » Mon Mar 25, 2013 10:14 am
if you look at the Porsche 911 pdk and non pdk models there's around 40kgs difference. And in a 911 that 40kgs is going to be right where you don't want it ;)
blueaudi
Post by blueaudi » Mon Mar 25, 2013 2:52 pm
adsgreen wrote:if you look at the Porsche 911 pdk and non pdk models there's around 40kgs difference. And in a 911 that 40kgs is going to be right where you don't want it ;)
Doesn't work like that in practice, little or no discernible difference on track or road. My only beef is that I miss the involvement of a manual change, but that's a personal thing.
2015 RS4 on the way
2014 SQ5
2011 Disco 4 HSE
2011 Mini One
adsgreen
Post by adsgreen » Mon Mar 25, 2013 3:05 pm
I can tell the difference with 40kgs in the boot of the RS4. Sure you can adapt the suspension to suit but you can't get away from the physics.
Anyway - that 40kgs you are lugging about everywhere.
blueaudi
Post by blueaudi » Mon Mar 25, 2013 4:49 pm
adsgreen wrote:I can tell the difference with 40kgs in the boot of the RS4. Sure you can adapt the suspension to suit but you can't get away from the physics.
I think I would also be able to tell the difference if I stuffed 40 kilo's in the boot of any car. I spent a day at the PEC back to back in PDK and manual, both had PDCC and I really could not tell them apart from a handling perspective, surprised and impressed in equal measure. Edited to say that they were 991S models, not driven a 997 PDK.
2015 RS4 on the way
2014 SQ5
2011 Disco 4 HSE
2011 Mini One
sakimano
Post by sakimano » Tue Mar 26, 2013 4:48 am
marzz wrote:
sakimano wrote:
PS. The term S-tronic can now refer to the dsg or tiptronic auto transmissions. The rs6 has s-tronic for example, even though is the 8 speed tip.
dsg/tiptronic/s-tronic are all different,
s-tronic is the only one with dual cluch, faster shifting (0.2s) and rev-matching on down shifts,
the s-tronic RS7 TT V8 got about 700Nm of torque so clearly the gearbox can cope with that, supped V8 RS4/RS5/R8 will have no more then 600Nm, so wouldn't worry
Try reading my post again
Audi now calls the dsg AND tc auto cars s-tronic. The big torque cars did not get the dual clutch dsg.
Adsgrren was talking about the dsg in the b8 rs4/RS5. He asked if b8 rs4/5 s-troni(dsg) can handle the torque of a good supercharger. I said it seems that Audi didn't think so since they opted to not use it on the big power/torque applications (rs6/7, s8), then mentioned the nomenclature change.
Then you came in late.
S-tronic is not dual clutch only. It is now used for the dsg (dual clutch) PLUS the torque converter 8 speed. S-tronic isn't a technology. Just a name for automatic now.
adsgreen
Post by adsgreen » Tue Mar 26, 2013 9:26 am
So kinda like the term 'Quattro' can mean perm 4wd like on the rs4 or haldex on others.
My concern with dsg boxes is that they have (I would have thought?) smaller clutch areas so limits lower than conventional gearboxes. However I know some tt-rs's are running high power/torque but a much lighter car.
blueaudi
Post by blueaudi » Tue Mar 26, 2013 11:15 am
Surely torque is the issue with DSG and S-Tronic, is that not why the big output diesel has the tiptronic box? What are Audi going to use in the RS6?
2015 RS4 on the way
2014 SQ5
2011 Disco 4 HSE
2011 Mini One
adsgreen
Post by adsgreen » Tue Mar 26, 2013 12:42 pm
blue62 wrote:Surely torque is the issue with DSG and S-Tronic, is that not why the big output diesel has the tiptronic box? What are Audi going to use in the RS6?
conventional auto - ZF8 speed.
blueaudi
Post by blueaudi » Tue Mar 26, 2013 12:55 pm
It's all getting rather confusing, but I take it that there are still load issues with DSG if they're resorting to a conventional auto? My limited understanding is that DSG and PDK are one and the same, so if Porsche offer PDK on the 911 Turbo, why no DSG on similarly powered Audi's?
2015 RS4 on the way
2014 SQ5
2011 Disco 4 HSE
2011 Mini One
marzz
Post by marzz » Wed Mar 27, 2013 12:15 am
is anybody actually using the water/meth setup on NA V8?
if so, what kit did you get?
marzz - my RS5 build
sakimano
Post by sakimano » Sun Mar 31, 2013 2:50 pm
We have seen loads of mechatronic failures with the b8 s4 stage two dsg guys. Not sure if the b8 s4 dsg is just not that good or if the heft and quattro and lots of early onset torque (the tvsr1320 supercharger is like instatorque) are the culprit because the gti guys are making more power and torque and the dsg is still fine. Those are turbocharged with a harder more sudden torque hit when boost kicks so you'd think the vw guys would be more at risk but they weigh 800 lbs less, and don't have quattro so they can easily overwhelm the tires giving the driveline a break... Whereas the b8 weighs 4050 lbs and is quattro.
ArthurPE
Post by ArthurPE » Sat Apr 06, 2013 2:33 am
awd is not forgiving on a clutch, 2 wd will spin the wheels to disapate energy until the clutch grabs, awd does not
I think the weak link in the dsg are the dual concentric main shafts, the inner is smaller diameter and the outer is hollow (the inner fits within it)
this makes both inherently weaker than one larger solid shaft
aren't the clutches a wet pack in dsg? this may limit torque capacity also
Users browsing this forum: No registered users and 147 guests
