FS: Brand NEW Audi RS4 B7 front Caramic Brake Kit 380 x 38
- Revolution
- Trader (Expired)
Re: FS: Brand NEW Audi RS4 B7 front Caramic Brake Kit 380 x
Sorry, daft Geordie humour took hold...
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
LittleDevil
- Trader (Expired)
One more 380mm RS4 B7 or B8 kit available. All installation parts are included.
Kind Regards
Kind Regards
- RossDagley
- Top Gear
Nothing for C6 RS6?LittleDevil wrote:One more 380mm RS4 B7 or B8 kit available. All installation parts are included.
Kind Regards
Previously:
Previously:
LittleDevil
- Trader (Expired)
With some adaption you can install RS6 C7 ceramic brakes on C6.RossDagley wrote:Nothing for C6 RS6?LittleDevil wrote:One more 380mm RS4 B7 or B8 kit available. All installation parts are included.
Kind Regards
Kind Regards
- RossDagley
- Top Gear
Could you be more specific please? What needs to be done, is there a readily available kit for this, and what is the likely cost if so?LittleDevil wrote:With some adaption you can install RS6 C7 ceramic brakes on C6.RossDagley wrote:Nothing for C6 RS6?LittleDevil wrote:One more 380mm RS4 B7 or B8 kit available. All installation parts are included.
Kind Regards
Kind Regards
Previously:
Previously:
LittleDevil
- Trader (Expired)
Fronts just need spacer between wheel hub and caliper holder + longer bolts for caliper installation, rears more difficult, because custom holder for caliper is needed, because rear is 370mm in diameter.
Ales
Ales
Softishman
- 2nd Gear
Re: FS: Brand NEW Audi RS4 B7 front Caramic Brake Kit 380 x 38
I wonder if you can source custom caliper brackets for an RS4 B7 and cermic brakes from a RS6 c7 370mm with ferrari handbrake calipers aswell?
Front (400mm) just needs spacer and center ring to fit..
A longshot but must ask!
@softishman on IG
Check out my RS4 there!
Can anyone please tell me what the thickness of the aluminum spacer is? I can't seem to buy just the spacer and I already have the R8 calipers and ceramic rotors. Will have a custom spacer made I guess... Cheers ~
- Surrey Sam
5mm spacer required to get the correct offset. However R8 callipers have no calliper carriers, as they mount direct to the suspension upright. So you'll need to get custom ones made as Audi don't sell them seperately.
Thank you Surrey Sam! My R8 calipers already have the mounting brackets attached, so I should be good, no?
- Surrey Sam
I can't answer that as R8s don't have carriers. So no idea what ceramic kit you're trying to fit. If 380mm and the callipers came with carriers they could be from a B7 RS4, B8 RS4/RS5 or S8.
My bad! The ceramic calipers are from a RS5, so that explains why they have the mounting brackets already attached. Thx again.
- Surrey Sam
No problem, you're welcome.
Hello,
Where might I be able to source 5 mm spacers for ceramic brake kit on the B7? Also will the spacers increase the tyre track or not and will I then need to install two others on the rear?
Users browsing this forum: No registered users and 184 guests
