Coil pack crisis
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re:
Post by HYFR » Sat Mar 05, 2011 1:03 am
neckarsulm wrote:I just find going to Audi like a visit to the dentist (only cheaper)
same here, i hate it
yorkie
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE:
Post by yorkie » Sat Mar 05, 2011 9:40 am
After starting this thread finally got mine done yesterday plus a new inlet manifold too.
pad125
Post by pad125 » Sat Mar 05, 2011 10:42 am
how/why did you get an inlet manifold?
RS6chris!
Post by RS6chris! » Sat Mar 05, 2011 10:44 am
If i ring my local dealer and ask will they tell me about this, and whether my car needs it just of VIN/Reg number?
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
wolfgang
Post by wolfgang » Sat Mar 05, 2011 11:00 am
^ My car is going in to Camberley Audi next week - Rob from there told me that they have to look at the coil packs first and then see if any need changing. They can only tell you that it's possible one or more coil packs need changing from your VIN apparently. If any of mine need changing then I'll need to book the car in again.
2007 RS4 Avant in Mugello Blue + Milltek non-res valved, MRC air filter, MRC remap with silent-mode startup
pad125
Post by pad125 » Sat Mar 05, 2011 11:04 am
Dont think it has anything to do with the VIN, I have the tech document if you want to PM me with your email and I can send you info
Steve_C
Post by Steve_C » Sat Mar 05, 2011 11:11 am
yes, they need to see your car before they know if any swaps needed
Gone to the dark side
PetrolDave
Post by PetrolDave » Sat Mar 05, 2011 11:26 am
aka_dk wrote:next you'll be saying B6/B7 Aux rads arent an issue ...
I can't and won't say that as I've had the RH aux radiator changed on my RS4 - never had a problem on the S4s though...
All I'm saying is, let's not blow this out of proportion, yes there is a problem with SOME coil packs, but that IMHO is as far as it goes.
AND Audi have in the past, and are now, dealing with it BEFORE owners got really angry about it (we haven't had to write to Jeremy Hicks on this issue like we had to to get DRC on their agenda).
yorkie
Post by yorkie » Sat Mar 05, 2011 11:35 am
EPC light kept coming on and going out again intermittently. Fault showing was "manifold flap position sensor (bank two) implausible signal intermittent". Sensor changed, no joy so manifold removed and flaps found to be sticking. New manifold comes complete with new sensors and actuators.
Rick_RS4
Re: Coil pack crisis
Post by Rick_RS4 » Mon Mar 07, 2011 8:49 pm
all 8 replaced today, and washed my car free of charge, i have paperwork for the records too, also no sales pitch for extras,
thanks Lincoln Audi
also the girl on the service desk was very tasty!
P_G
Post by P_G » Mon Mar 07, 2011 9:09 pm
yorkie wrote:EPC light kept coming on and going out again intermittently. Fault showing was "manifold flap position sensor (bank two) implausible signal intermittent". Sensor changed, no joy so manifold removed and flaps found to be sticking. New manifold comes complete with new sensors and actuators.
Fault code P2021? Funny that because a course of DIP3 injector cleaner and a some good runs out on V-power solved mine. But then Audi are good for just replacing everything associated with a problem under warranty.
yorkie
Post by yorkie » Mon Mar 07, 2011 9:27 pm
Got to see the old manifold, definitely sticky flaps and I'm not complaining! :bigblink: I am also surprised that an injector cleaner (assuming that is what it is) or even V Power had any effect when the fuel doesn't go through the manifold. Anyway, glad it did sort it for you. :jump_clap:
P_G
Post by P_G » Mon Mar 07, 2011 9:35 pm
Sticky with what? I'm genuinely curious.
It's not necessarily the petrol that clean the manfold as that is not DI technology as you know, more to do with the Ketane in it gettting through the piston seals before they are up to temperature on valve overlap which is where oil deposits that contribute to CB appears to come from in the first place.
yorkie
Post by yorkie » Mon Mar 07, 2011 10:58 pm
The shaft bushes were worn causing the flaps to stick randomly. When you moved them by hand they sort of clicked rather than moving smoothly. I guess sometimes they clicked enough to keep the sensors happy and other times they didn't. I'm also guessing that since the shafts exit the manifold and were wobbly there may have been some loss of vacuum but I have to report no power gain has ben noticed. :(
wolfgang
Post by wolfgang » Wed Mar 09, 2011 3:26 pm
Had my coil packs checked today and they were all okay, so I guess it's the luck of the draw...
Users browsing this forum: No registered users and 146 guests
