SEAT Exeo RNSE Sat Nav in B7 RS4...
ChrissDeejay
Re: SEAT Exeo RNSE Sat Nav in B7 RS4...
Post by ChrissDeejay » Mon Sep 28, 2020 7:45 pm
Sorry for my late response.
I have tried multiple times to code it but it simply doesn`t accept the coding.
It is the same error message as I mentioned before.
Could it be that Exeo firmware does not support AMI ? :(
ChrissDeejay
Post by ChrissDeejay » Tue Jan 12, 2021 7:59 pm
Hello all,
Unfortunately the Nav refuses coding even with a different VCDS interface.
Attached you can find all the NAV details (PN, SW and actual coding).
The main issue is that the AMI coding is refused with error 31 (coding out of range).
Could be a software fault ? Should I try to reflash it with an older software ?
Thank you !
RNS_E data.txt
(1.12 KiB) Downloaded 98 times
mikep99
Post by mikep99 » Tue Jan 12, 2021 8:37 pm
Chris,
Your firmware looks different to mine
yours H05 0710
mine H06 0220
same Seat Exeo RNSE.
Maybe Jon can see what he has ?
Mike
mikep99
Post by mikep99 » Tue Jan 12, 2021 9:10 pm
Just been having a search online...
I think 710 is a hacked version of the firmware, there is some mention of firmware 700 if you do a search.
Latest RNS-E mk2 official firmware is 220 as far as I'm aware.
Mike
Jon_J
Post by Jon_J » Tue Jan 12, 2021 9:13 pm
One of them is H06 0220, the other is H06 0200.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
ChrissDeejay
Post by ChrissDeejay » Wed Jan 13, 2021 3:51 pm
Yes, you are correct.
My firmware is 0710 because I used the hack tool in order to enable any DVD to be used for maps (https://www.digital-eliteboard.com/thre ... 30.452132/).
But the only thing that this tool does is to increase the FW version, so that RNS-E detects it as an update, and also removes the burner protection.
Could there be any differences ... hardware wise (H06 vs H05) ?
LE : In the meantime I got my answer from the hack-tool forum : Units with 710 Sw don’t work with backup cam and ami !
LE 2 : So now I have to find a way to revert the unit to last Audi official software ...
Thank you very much for your support !
pcbbc
Post by pcbbc » Mon Apr 12, 2021 12:08 pm
193 units with firmware 0220 onwards are running the Audi firmware (V574 hardware platform).
193 units with firmware 0700 onwards are running the Seat firmware (VB48 hardware platform).
So an outwardly apparent Seat Exeo unit that is showing 0220+ firmware has either...
* Had it's motherboard replaced with one from an Audi.
* Been cross flashed with the alternative firmware.
ChrissDeejay is correct: The Seat firmwares have AMI, reversing camera and OPS disabled.
However I have done some work to re-enabled them, and I now have some an alpha firmware available to fix this. It's not available for public download yet, but you can visit my RNS-E firmware update site here.
Best to send a support request if you need me - I may not check back here that often :)
ChrissDeejay
Post by ChrissDeejay » Mon Apr 12, 2021 1:29 pm
I can confirm that the alpha firmware is working great on Seat RNS-E + AMI. :)
:thumb: :thumb: @pcbbc ! :)
Users browsing this forum: No registered users and 175 guests
