Turbo options
Weiß-sechs
Re: Turbo options
Post by Weiß-sechs » Thu Jan 16, 2014 5:54 pm
Shoppinit wrote:You went with AET in the end?
What did they set you back?
You doing any other mods to go with them?
Yes, AET did them, got the Millie race dp's to go on as well, should be good for 600hp+ with a good map :boots:
Re: Turbo options
Post by bam_bam » Thu Jan 16, 2014 6:24 pm
Who's mapping?
Weiß-sechs
Re: Turbo options
Post by Weiß-sechs » Thu Jan 16, 2014 6:27 pm
The guys doing the install initially, probably get a full dyno map when time allows
Re: Turbo options
Post by bam_bam » Thu Jan 16, 2014 6:32 pm
Do they have enlarged intakes? If so, how wide?
Weiß-sechs
Re: Turbo options
Post by Weiß-sechs » Thu Jan 16, 2014 6:40 pm
Not sure on exact dimensions but my man reckons they're a LOT bigger than OEM, they're chamfered to allow more flow for the K06 compressor
Mr V10
Re: Turbo options
Post by Mr V10 » Thu Jan 16, 2014 8:10 pm
I hope you get to that figure, but I'll be very surprised if you do.
Keep us posted, and good luck.
Weiß-sechs
Re: Turbo options
Post by Weiß-sechs » Thu Jan 16, 2014 8:38 pm
The spec of the hybrids means that they'll flow 35lb per minute; with a very approximate conversion ratio of 10:1 for air flow to bhp that's 350 bhp (a similar K04/06 hybrid on the 1.8T engine makes a solid 330bhp). So, bearing in mind that there's two compressors filling the cylinders that's a potential of 700 bhp. Obviously, there's a lot more science to it than that when factoring in flow through manifolds, ic's, exhausts etc. etc. but with keeping back pressure to a minimum through the race dp's and decatted system plus Waggies adding to the flow rate then 600 should be do-able........don't reckon my slushbox is going to be appreciative though..... :thumbsdown:
Re: Turbo options
Post by bam_bam » Thu Jan 16, 2014 8:55 pm
So you're going to get some custom intakes made up? IIRC you've already got Comp Lower Gaskets, ne?
The MTM spec was apparently good for 568HP with sports CATs, CLG and hybrids. It'll be that extra 30HP that's the hardest to get, I'm very sceptical of anyone but Mihnea mapping C5s anything past a stage 1.
I'd love to know how different the HP/lbs ft curves would look with modded K06, K16, K24 and TTRS comp wheels. I really wanted to put the TTRS comps in but bottled it at the last moment. It'd never been done and I somehow got worried about lag. I don't think I should've worried. Apparently the hotside held everything back.
Weiß-sechs
Re: Turbo options
Post by Weiß-sechs » Thu Jan 16, 2014 9:09 pm
Mihnea will be having the final say in what this set-up will make but ATM we'll have to suck it and see. No cats are so much better than sports cats :bigblink:
The TTRS comp wheels would be great for top end boost but not what I'm after; K06 compressors give a much smoother torque curve, a lot more road biased which is the way to go with an RS6 IMO, we all know they're no track toy
Mr Footlong
Re: Turbo options
Post by Mr Footlong » Thu Jan 16, 2014 9:39 pm
Weiß-sechs wrote:No cats are so much better than sports cats :bigblink:
My big bottom. I get bloody good figures on my Milltek Sports Cats and have no potential dicking about come MOT time :bigblink:
Current:
Gone:
Weiß-sechs
Re: Turbo options
Post by Weiß-sechs » Thu Jan 16, 2014 10:00 pm
Agreed, Milltek cats are SO much better than the restrictive OEM & keep you nice & legal but if you want to release the full potential of any turbo'd motor then keeping back pressure to an absolute minimum is the way forward ie. NO cats, not even silencers if you can stand it (Bam)
As an experiment in total irrelavence and if you're bored with time on you're hands sometime etc then get down to MRC or closest four wheel dyno & get a power run with cats removed.....you'll be impressed :thumbs:
dubbed_up_daz
Re: Turbo options
Post by dubbed_up_daz » Thu Jan 16, 2014 10:40 pm
What is the main differences/advantages off these over loba 650s?
Weiß-sechs
Re: Turbo options
Post by Weiß-sechs » Thu Jan 16, 2014 11:44 pm
Not a great deal really other than AET are relatively local to me (as opposed to Germany anyway) and they've got a good rep
Re: Turbo options
Post by bam_bam » Fri Jan 17, 2014 12:24 am
dubbed_up_daz wrote:What is the main differences/advantages off these over loba 650s?
Price due to less marketing. All the same sort of tech is but Loba will tell you their tolerances are tighter, their computer design is better and to be fair, they do produce some very pretty graphs.
Problem is, without the stars and moons aligning and every conceivable mod supporting the Loba snails, they won't make claimed power, ask Panda.
Weiß-sechs
Re: Turbo options
Post by Weiß-sechs » Fri Jan 17, 2014 9:29 am
That was a major factor in my not going down the Loba route; as far as price is concerned I could have sent my originals straight over to Loba in Germany and got them re-manufactured to "650" spec for about the same money (the Loba units are actually less but overall approx the same amount when factoring in courier costs etc.) but I reckon they're being a little optimistic with the power figures. It takes a big leap of faith to get from the 510bhp or so that I'd got originally up to the 650 claimed by Loba just by swapping the turbos; AET were a lot more realistic in their claims that with the other mods 600bhp is certainly attainable & tbh I reckon that if mine was pushing 510 with WELL worn K04's and with standard pre-catted dp's etc. another 90 bhp should be relatively simple to find with the much better flowing hybrids plus race dp's and a decent dyno map. Just a case of "you pays your money, you takes your chance" :mrgreen:
Users browsing this forum: No registered users and 92 guests
