Terraclean for rs4?
Re: Terraclean for rs4?
Post by HYFR » Mon May 20, 2013 10:38 pm
RS 5 runs hotter than the B7
Mine put down 432PS
adsgreen wrote:
barryrs wrote:
adsgreen wrote:Exhaust valves will be cleaner - as the VW patent suggests, carbon deposit buildup is very dependant on temperature and high temps do break it down.
This seems to be a fix that Mercedes have produced for some models although its designed to burn carbon off the exhaust manifold in this case.
The tech loads a specific engine map that runs that car throughout a specific rev range building up to a extended high revving until the exhaust manifold glows. My brother said it was quite disconcerting the first time they did it but it seems to work very well.
I've seen this for turbo based unit (granted, not petrol) but didn't know if this was being done for NA engines.
The other alternative is to very carefully run the engine lean for a bit. Obviously need to be careful but it wouldn't take long to dramatically increase the cylinder temp to get the carbon off or even prevent it from sticking.
adsgreen
Post by adsgreen » Tue May 21, 2013 7:17 am
Need to consider other factors - for example, the original b7 rs4 would have euro IV in 2006 but current cars need to meet euro V... An easy way of reducing emissions is to simply increase the engine running temperature.
Downside is this reduces power...
What would be good is a dual temp control system so the engine runs hit for economy and emissions when just cruising but drops everything down when going for the power.
Gavla
Post by Gavla » Tue May 21, 2013 8:15 pm
Just an update… I've been in contact with Terraclean and Jags at Performance Tuning UK (they're fairly local to me) and after reading through recent posts I am curious to see if it works so I've decided to have my car Terracleaned. They are planning to document the process with boroscope images so hopefully this will provide some actual tangible evidence. I am hoping that it works but like a few on here I'm sceptical. The proof is in the pudding as they say. ;-)
The work they’re undertaking is as follows:
Rolling Road test before the service
Emissions test before the service
Borescope with colour images before the service
Perform the Terraclean service (without using any other additives)
Rolling Road test after the service
Emissions test after the service
Borescope with colour images after the service
They intend on logging all the information to be able to upload it onto the forum for everyone to see.
Also they are very generously not charging a single penny for this work so thank you Jags :thumbs:
Watch this space....
RS4 (B7) Saloon Phantom Black, Black Optics, Tech Pack, KW Lowering Spring Kit, Stern Adjustable Arms, MRC Stage 2, Stage 1 Manifold, CAF, LOBA Stage 1 Clutch,
447ps/490nm (MRC), Scorpion Exhaust Non-Res Black Tips, Pre-cats gutted, Shadow Black Chrome Alloys, Viper Alarm, LED Interior lights, Tints
Post by MikeFish » Tue May 21, 2013 8:17 pm
Good stuff. When you having it done?
Gavla
Post by Gavla » Tue May 21, 2013 8:21 pm
Hi Mike, should be later next week... ;-)
ArthurPE
Post by ArthurPE » Tue May 21, 2013 8:44 pm
do one more thing if you please
some before/after 3k to 8k 3rd gear runs
stu
Post by stu » Tue May 21, 2013 11:00 pm
The bit about the boroscope... I thinking I'm getting deja vu here.
Didn't someone already try this but was unable to view the all important areas? I think the horoscope didn't flex beyond ninety degrees.
TonyHayers
Post by TonyHayers » Wed May 22, 2013 12:05 am
stu wrote:The bit about the boroscope... I thinking I'm getting deja vu here.
Yeah, you need a decent one with a "pointable" camera head. Either that or keep jamming it into your cylinder until it bends and points upwards (and makes a nice pattern on the cynlinder walls :)
06 Phantom Black Saloon:
^ GONE :cry:
adsgreen
Post by adsgreen » Wed May 22, 2013 8:01 am
Nah - you just need one that has a mirror attachment. Plenty out there that have a reverse view (say 150 degrees)
Gavla
Post by Gavla » Wed May 22, 2013 8:35 am
ArthurPE wrote:do one more thing if you please
Yes sure no problem - will record on iPhone and play it back to accurately work out several avg time(s).
EDIT:
I have done one on the way back from a client and it worked out to be 7.91secs (taken from the iPhone video). I'll need to do some more to take an avg...
Gavla
Post by Gavla » Wed May 22, 2013 9:16 pm
Well I've done another 3 of Arthurs test runs tonight (floored it at 2K) all very similar and all taken from the video file(s) by measuring the elapsed time between 3K-8K. The only difference was in ambient temperature 10C. Above (7.91) it was 12C....
#1 7.07 secs
#2 7.08 secs
#3 7.11 secs
Avg 7.08 secs
Is this any good? What's the norm?
adsgreen
Post by adsgreen » Wed May 22, 2013 10:22 pm
A lot more than that iirc!
ArthurPE
Post by ArthurPE » Wed May 22, 2013 10:38 pm
norm is 8-8.5 sec at 22 C or so
Gavla
Post by Gavla » Wed May 22, 2013 11:17 pm
Thanks - will try these again once it's been cleaned. :thumbs:
sakimano
Post by sakimano » Mon May 27, 2013 6:57 pm
Gavla wrote:Thanks - will try these again once it's been cleaned. :thumbs:
Unless you're running a small supercharger, those 7.0 times are pretty incredible. Care to explain the method for making the times? Are you going to post the video soon?
It works well to just have the on board stopwatch running wihle you film the DIS+tachometer+speedometer. That way you can pause the video right at 3k, look at the time on the DIS stopwatch, then do the same at 8k.
As I said however 7.0 is not far off what APR supercharged cars run.
Users browsing this forum: Bing [Bot] and 219 guests
