Re: Help please - gearbox issue - BAD BAD NEWS!!
Mr Footlong
Re: Help please - gearbox issue - UPDATE!!
Post by Mr Footlong » Wed Mar 13, 2013 7:51 am
ant1 wrote:MRC won't touch recon boxes. I called them up last week to see if they would offer the same service as AMD for a recon box with warranty fitted for 3.5k.
He said he only fit new.
Not true or at least needs more detail, which I will provide. They will only SUPPLY new boxes. While they won't supply and fit recon boxes, they will fit customer-provided recon boxes but for obvious reasons cannot warranty any of the work within the box. Daveperc had them fit his heavily uprated gearbox & TC and one day they will fit mine too unless AmD ever come back to us with more detailed info on their drive in, drive out bombproof box option....
Current:
Gone:
Daveperc
Post by Daveperc » Wed Mar 13, 2013 10:19 am
And very fine it is too!! :)
ant1
Post by ant1 » Wed Mar 13, 2013 10:44 am
That's what I was told and I was given no other option. Even if they would fit a supplied recon box, who in the right mind would take the risk! It all needs to be done in house by the same person so you can't get each party blamming each other for either poor fitting, or poor rebuild. That comes from experince.
Mr Footlong
Re: Re: Help please - gearbox issue - UPDATE!!
Post by Mr Footlong » Wed Mar 13, 2013 10:59 am
Have you put any business MRC's way before? If you haven't then they can well be wary of new customers with requests like this as they can bite them in the ass. If you know what you are talking about, have dealt with them before and are not trying trying to get them to slap in some random POS recon slushbox then you shouldn't have a problem, you just have to be aware that they cannot be held responsible for defects within the random box, as you have also mentioned in your reply.
I await Doug coming on here to tell me that their policy has changed since Daveperc's escapades ;)
Current:
Gone:
ant1
Post by ant1 » Wed Mar 13, 2013 5:34 pm
Mr Footlong wrote:Have you put any business MRC's way before? If you haven't then they can well be wary of new customers with requests like this as they can bite them in the ass. If you know what you are talking about, have dealt with them before and are not trying trying to get them to slap in some random POS recon slushbox then you shouldn't have a problem, you just have to be aware that they cannot be held responsible for defects within the random box, as you have also mentioned in your reply.
Putting business there way previously has nothing to do with what I posted above. My point being was that I was told they do not use recon boxes, only new.
Should make no difference if I'm regular or not.
Just to make this clear, I'm not moaning or complaining just posting what I was told :)
imacool
Post by imacool » Thu Mar 14, 2013 10:48 pm
chunky79 wrote:Tis true that some get faults after a g-box service. Grizz did mine about 10k ago and the oil was like new, i will get it changed every 20k.
Do you have to leave the car overnight at Unit20 to change the ATF? From various posts it seems crucial to have ATF temp at 35 degrees when changing it, so just curious...
current: Quartz Grey A6 C6 Avant 3.0 TDI Le Mans
prev:Daytona grey RS6 C5 Avant,Black BMW 320D Coupe (E92),Red Honda Accord 1.8
mavada
Post by mavada » Thu Mar 14, 2013 10:53 pm
At ZF in Germany they put some ventilators beneath the car the speed up the cooling process...
With that method, ofcourse depends on the temp of the box, will take 2-4 hours, incl oil refilling...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
imacool
Post by imacool » Thu Mar 14, 2013 11:09 pm
Thanks.
Post by chunky79 » Fri Mar 15, 2013 7:12 am
Nope, had it done on a sat morning. To be fair, 2 hour drive up to him gets the car lovely and warm, then it doesn't take long to get the new oil back upto temp.
captrs6
Re: Help please - gearbox issue - FINAL UPDATE!!
Post by captrs6 » Mon Mar 18, 2013 8:20 pm
After lettling the car settle,re-draining gearbox (new fluid), re-scanning, the issue has not re-appeared!! :nogarors4:
Car is responsive in both the paddle and autobox gear changes!! :biggrin3:
I appreciate that this is early doors - only about 400 miles, but all seems well..
Thanks All... :beerchug:
2003 C5 RS6 - Stage 1 Re-map, KW Coilover Kit.
The C5 is the S&M of car ownership - "Pleasure and pain".
rossi46
Post by rossi46 » Mon Mar 18, 2013 9:18 pm
FWIW, Doug @ MRC told me they never allow customers to supply their own parts. I suspect this policy has some flexibility however, depending on who you are.
I've also put a decent amount of work their way.
sweegie
Post by sweegie » Mon Mar 18, 2013 9:23 pm
captrs6 wrote:After lettling the car settle,re-draining gearbox (new fluid), re-scanning, the issue has not re-appeared!! :nogarors4:
This definitely qualifies for a Yippee-ki-yay :D
Top result :thumb:
Recycling dinosaurs for fun
rossi46
Post by rossi46 » Mon Mar 18, 2013 9:49 pm
Nice one captrs6 :beerchug:
stoddie
Post by stoddie » Tue Mar 19, 2013 8:38 pm
glad to hear it mate :biggrin3:
captrs6
Post by captrs6 » Sat Mar 23, 2013 7:26 pm
So - the post I dreaded to type has came true.. :boohoo:
Gearbox issue has came back worse than before..
Once the car heats up, and the car is running at temperature, (using the paddles) - the car struggles to get into 2nd gear - high revs and then clumps into 2nd. On occasion it actually decidesto go through the gears itself when in paddle mode..even tho I am going 20 mph!!
Using the autobox - the car struggles to get into any gears!!
Not a good sign I admit .... :drink:
Sad times....
Users browsing this forum: No registered users and 207 guests
