chunky79 wrote:I would be suprised if the new fronts turned up!
RS 51X CS,daytona avant
dubbed_up_daz
Re: RS 51X CS,daytona avant
Can hardly call them new I suppose.
Yeah, they'll be antiques by the time they make an entrance.chunky79 wrote:Can hardly call them new I suppose.
dubbed_up_daz
#antiquesroadshowbound
Daz
You just won your first show award
Tiger stripes 1 - 0 Zebra stripes
toofattodrive
Would you mind letting me know the estimated cost of this entire prep work and the full respray?dubbed_up_daz wrote:Paintshop update....
Car has been fully paint depth checked. One main panel had had a couple blow overs but no filler so either keyed or bad stone chips been covered up a couple times. Almost every other panel has had a blow over at one point or another but all is now in check. All panels have now been taken to the same average depth and the bad panel was taken back down to bare metal and built back up to the same depth as the rest and a pre primer primer has been dusted over....
dubbed_up_daz
6.9k for paint. 1.5k for parts
- daytonamart
- 5th Gear
Blimey Daz, that's commitment! fair play to you. I can see why the gearbox going isn't good news.
Gone B7 RS4 Sprint Blue Avant
Gone B7 A4 Reflex Silver
dubbed_up_daz
It crept up during the job tbh, when I counted up the final bill I had heart failure. The box dying within 3 days wasnt part of the plan. In hand now though. Spare rs6 turbos bought and soon to go for hybridisation, car goes in for remedial paintwork tomorrow night and then it should be away to unit20/mrc then its just the interior fiasco to sort and the car will be almost exactly as I want it....
dubbed_up_daz
Booked in for box fix finally. Got it back from the paintshop and all is good although I still have the headlight level warning coming up and he's (the painter) had a chat with an audi tech and that could be because the car is lowered....although it was fine the two months beforehand
And still fk all word about the interior.....
It's a common problem. Talk to Audi and it's an expensive fix, talk to MRC and it's a £10 part. It shouldn't matter if it's reasonably lowered.dubbed_up_daz wrote:Booked in for box fix finally. Got it back from the paintshop and all is good although I still have the headlight level warning coming up and he's (the painter) had a chat with an audi tech and that could be because the car is lowered....although it was fine the two months beforehand![]()
bam_bam wrote:It's a common problem. Talk to Audi and it's an expensive fix, talk to MRC and it's a £10 part. It shouldn't matter if it's reasonably lowered.dubbed_up_daz wrote:Booked in for box fix finally. Got it back from the paintshop and all is good although I still have the headlight level warning coming up and he's (the painter) had a chat with an audi tech and that could be because the car is lowered....although it was fine the two months beforehand![]()
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
dubbed_up_daz
Why would it appear after running fine for over two months lowered though? And the car goes into unit 20 next week but will be at mrc afterwardsrfor mapping probably so will be sorted out at somepoint...bam_bam wrote:It's a common problem. Talk to Audi and it's an expensive fix, talk to MRC and it's a £10 part. It shouldn't matter if it's reasonably lowered.dubbed_up_daz wrote:Booked in for box fix finally. Got it back from the paintshop and all is good although I still have the headlight level warning coming up and he's (the painter) had a chat with an audi tech and that could be because the car is lowered....although it was fine the two months beforehand![]()
The front-end/front lights came off, right? There's an assembly in the front wing, it's a weird switch or sommit that fails. Speak to Doug, he'll point out which parts are required, he's done a billion of them.
dubbed_up_daz
Users browsing this forum: No registered users and 327 guests
