TTS Supercharger development for RS4
Re: TTS Supercharger development for RS4
Post by HYFR » Mon Oct 10, 2011 2:41 pm
doug, it looked VERY fast coming into camp corner
Doug_S2
Trader (Expired)
Post by Doug_S2 » Mon Oct 10, 2011 3:05 pm
P_G wrote:Excellent results Doug. What do you believe to be the reasons on why it doesn't produce as much Torque as the S5 you have developed, 617 vs 651? Is that just down to mapping and you are still tweaking to get more torque out of the RS4?
The S5 revs to 7k and the rs4 revs to 8k(ish), and becasue the charger has a maximum safe rpm to rev to, you have to gear it(with the pulley size) to be on that limit at your peak revs. Becasue the rotrex boost is proportional to revs, and the rs4 has to rev higher you open up the revs you have and so lose some lower down torque compared to the S5. The other thing is they have different cams and exhaust manifolds.
http://www.MRCtuning.com
P_G
Post by P_G » Mon Oct 10, 2011 3:12 pm
Should have worked that out for myself really, thanks anyway. Just need to save up now. :beerchug: How long do you intend to run the kit for and are you doing monitoring tests on the car during that time for durability / wear & tear?
Doug_S2
Trader (Expired)
Post by Doug_S2 » Mon Oct 10, 2011 3:26 pm
We are monitoring. We have a data logger that we are wiring up this week (i never had time befor ethe weekend) to monitor lots of temps and pressures. The car is going to the nurburgring this week for a few days to test it. Oil samples before and after will be sent to be monitored.
RS4POWER
Post by RS4POWER » Wed Oct 12, 2011 6:40 am
Doug- Looks like the tq limiter is back in play? If so, I don't blame you guys trying to protect the drivetrain..
Did you guys upgrade the lwfw/clutch?
Impressive results! Keep up the good work!
Doug_S2
Trader (Expired)
Post by Doug_S2 » Wed Oct 12, 2011 6:48 am
There is no torque limiter. This supercharger kit is a centrifugal/rotrex style so the torque curve is rising. The screw/roots type give more of a flat torque curve and slightly higher at low revs. This style is so efficent instead of keeping torque flat it rises at high revs. This charger is going to be less abusive on the clutch so a good stock clutch would be ok if driven sensibly as torque is always progressive.
JackS4
Post by JackS4 » Wed Oct 12, 2011 7:50 am
How does the charged RS perform side by side with the charged S4 ? Does the extra torque in the S4 give it an edge?
J
klauster
Post by klauster » Wed Oct 12, 2011 9:43 am
Is this another £20k kit?
Doug_S2
Trader (Expired)
Post by Doug_S2 » Wed Oct 12, 2011 9:52 am
£10900+vat for the RS4 Supercharger kit which includes the 2 uprated hi pressure fuel pumps.
adsgreen
Post by adsgreen » Wed Oct 12, 2011 10:11 am
Doug_S2 wrote:There is no torque limiter. This supercharger kit is a centrifugal/rotrex style so the torque curve is rising. The screw/roots type give more of a flat torque curve and slightly higher at low revs. This style is so efficent instead of keeping torque flat it rises at high revs. This charger is going to be less abusive on the clutch so a good stock clutch would be ok if driven sensibly as torque is always progressive.
Just to put this into context I uploaded Doug's dyno plit into my sim software and it reckons for a stock B7 RS4 the optimum method of launching the car is a dumping the clutch at 6400 (resulting in a 0-60 of 4.56 and 0-100 of 11.10. For the TTS/MRC car it's calculated the best is dumping the clutch at 1800 rpm (3.45 to 60 and 7.49 to 100).
It may be a little off with the centrifugal supercharger but the graphs seem to match the dyno plot.
Stoffle32
Post by Stoffle32 » Wed Oct 12, 2011 10:13 am
around the same price as the APR kit, guessing that does not include instillation?
ROTREXPOWER
Post by ROTREXPOWER » Wed Oct 12, 2011 6:27 pm
Unfortunately, but fortunately we make so much power we need the pumps. Without the pumps we would be limited by about 80+bhp, we could only get 570 bhp and then leaning out to much, now we can run 660 on 102 octane with no problem. The good thing is that we have analysed the pumps and feel we can make the parts in the UK at a much better price and so keep the overall price down a little. Dougs getting the clutch in my S5 over the next week, then after bedding in we will try some 0-60's and put the car on some independant dyno's. :)
P_G
Post by P_G » Wed Oct 12, 2011 7:49 pm
Are you going to sell this exclusively through MRC or can those handy enough purchase to DIY install?
S4Player
Post by S4Player » Wed Oct 12, 2011 11:33 pm
So is this the 'finished article' Richard with regards to the rs4 kit? I said to Doug with more torque I'd consider keeping my b7, Doug/Richard what boost are you putting out to make these numbers?
Doug_S2
Trader (Expired)
Post by Doug_S2 » Thu Oct 13, 2011 8:49 am
You can buy the kit to DIY fit yourself.
This kit runs 14psi Danny. There is a 2 year parts warranty on the kit so you cannot overspin the charger to give more sooner - you could use a diffrnet pulley if you dropped the rev limiter though, if torque was more of a priority.
Users browsing this forum: No registered users and 349 guests
