RS4 Engine Pull Tools & Longer 5th/6th gear parts
viperbl
Post by viperbl » Sun Sep 02, 2007 9:37 pm
RS4 B5 Saloon8) with 750+ bhp :D
musty1
Post by musty1 » Sun Sep 02, 2007 9:41 pm
nice rich, the drive shafts are spline not torx well on my car they are a6 2.7t hopen that helps
1.9TDI A6 are sh*t wrong forum
viperbl
Post by viperbl » Sun Sep 02, 2007 9:52 pm
musty1 wrote:nice rich, the drive shafts are spline not torx well on my car they are a6 2.7t hopen that helps
AHHH! nice one! I don't have any splines ... well, I am off to buy another new set of nice shiney bits 8)
Cheers :D
viperbl
Post by viperbl » Sun Sep 02, 2007 10:20 pm
Just some pics of the old 6th gears ...
viperbl
Post by viperbl » Mon Sep 03, 2007 3:21 pm
Spot on Musty, thanks, spline it was ... nearly there now :D
musty1
Post by musty1 » Mon Sep 03, 2007 3:39 pm
no probs do you know where I can get some banjo fittings from??
Are you off to the ring??
viperbl
Post by viperbl » Mon Sep 03, 2007 3:49 pm
musty1 wrote:no probs do you know where I can get some banjo fittings from??
Gonna run the car tonight and also take it to the garage that done the work before for me to give it the once over ... That all going well, I am definatly taking it Germany ... not 100% on the ring yet, although I think I will, and just try and take it easy ...
Banjo? ebay maybe?
MarkB
Post by MarkB » Mon Sep 03, 2007 9:13 pm
Nice work Rich, glad to see it all back together...
Mark
viperbl
Post by viperbl » Mon Sep 03, 2007 10:43 pm
Cheers Mark :)
Right, just been for a drive, everything seems perfect!! The beast is back! :P
Ok, the 6th gear, the parts work, so thats good. Now, the drop from 5th to 6th is quite large, you can't use it under, hmm, 45ish maybe ... well test.
When gunning it, the drop is quite large, but I think if redlining 5th then to 6th, it will be just fine, because its not going to drop below 3800rpm where my torque is ...
viperbl
Post by viperbl » Tue Sep 04, 2007 9:10 am
A little dark last night!
I willl try and get some better ones today ...
dummi
Post by dummi » Tue Sep 04, 2007 10:16 pm
viperbl wrote:Cheers Mark :)
go any examples , like when are you shifting
viperbl
Post by viperbl » Tue Sep 04, 2007 10:54 pm
dummi wrote:go any examples , like when are you shifting
What do you mean??
Well, the garage picked up on a few things wrong with my work... mostly little things, the main ones where ...
- FMIC rubbing on AC rad
- IC pipe rubbing on additional oil cooler pipe
- Subframe was a little off centre, only a couple of mill, but enough to possible cause problems ... there are three rings on both sides at the front of subframe which you need to stick a bar through and line up correctly.
Overall I am quite pleased, I know the subframe is a big one, but then thats why I had a pro look at it!
Every day is a school day at the moment!
dace
Post by dace » Tue Sep 04, 2007 10:56 pm
So we have the all clear then Rich?
viperbl
Post by viperbl » Tue Sep 04, 2007 11:05 pm
dace wrote:So we have the all clear then Rich?
YES! (once the problems are fixed! :lol: )
I have addressed every problem except the subframe, the car is up and ready to fix that tomorrow. Once thats done ... we are good to rock and roll Dave!!!
dace
Post by dace » Tue Sep 04, 2007 11:09 pm
:jump_clap: :smile_smoking:
