Faisal’s R8
FaisalJ
Re: Faisal’s R8
Post by FaisalJ » Sat Apr 21, 2018 8:54 pm
MikeFish wrote:Del is a wheel legend, he knows his stuff.
Not sure I'm a fan if the BBS wheels on an R8 but I know you like them.
Loving that carbon though, so sexy.
And you went for gygeon over gtechniq in the end? What swayed you? Be interested to hear your thoughts compared to the gtechniq after you have had it for a while.
The gyeon stuff seems to be getting a lot of praise and compared favourably with gtechniq in tests so thought I’d give it a go!
2007 RS4 B7 Avant
Eddie555
Re: Faisal’s R8
Post by Eddie555 » Sat Apr 21, 2018 9:17 pm
Nice. Very nice. I can’t wait for my Mrs to get her confidence up enough to drive my new Q7 so I can sell her A3 and buy me an R8. Gimme a year buddy and I’ll be joining you.
Current ride’s
Previous rides
Re: Faisal’s R8
Post by MikeFish » Sat Apr 21, 2018 9:46 pm
Wow looks stunning. I take it back about the wheels, they do look good, just don't like the chrome rim protector.
Just picked mine up today after a detail and gtechniq top up, just wish they stayed looking like this for longer.
Re: Faisal’s R8
Post by bam_bam » Sun Apr 22, 2018 12:46 pm
Noice!
C6Dia
Re: Faisal’s R8
Post by C6Dia » Mon Apr 23, 2018 12:15 pm
Very nice! Looks fantastic
MY09 C6 AVANT 843bhp in progress
MY10 C6 SALOON MRC 775ps
MY15 D4 S8 MRC 676ps
MY14 F10 M5 DMS 748bhp
MY10 C6 RS6 SALOON MRC 719.9ps
FaisalJ
Faisal’s R8
Post by FaisalJ » Sun May 20, 2018 4:12 am
Bit of an update on the wheels and fitment
So the OEM wheels specs are the following:
- Front: 19x8.5, ET42. 235/35/19 tyre
- Rear: 19x11, ET50. 295/30/19 tyre
The BBS CH-R II do not come in a perfect fitment for the R8 unfortunately, and the R8 is not listed as a compatible fitment by BBS. However, Delroy at Prestige was fairly sure the following would work:
- Front: 20x9, ET30, 245/30/20 tyre
- Rear: 20x10.5, ET35, 305/25/20 tyre
So, they were ordered up and I crossed my fingers!!
They were sent straight to the garage, who fitted the H&R lowering springs before the wheels went on. Unfortunately - the concave of the rear wheel meant it was fitting the caliper. A few frantic calls between myself, Delroy and Camspec later - some 10mm H&R hubcentric spacers were sourced from Eurocarparts the same afternoon and the wheels went on! The spokes of the wheels were literally grazing paint off the caliper, that’s how tight the fitment was - so I changed to 11mm spacers soon after.
However, another problem was to follow!
As the springs settled slightly, started to get worse and worse rubbing in the arches - mostly at the front. To the point that I couldn’t drive the car properly and was dodging bumps in the road. Not good.
Nothing for it - I had to take a dremel to the plastic arch liners!
Note that there is also an outer wheel arch cover, removed in the pics above, that stayed untouched.
This improved things a lot but not 100%
So I took the car into Tuningwerkes in South Croydon- who deal with a lot of lowered cars, to see what they could do. They solved the rubbing at the rear, by trimming a small amount of plastic- but were unwilling to do too much trimming up front. When I collected the car, it was parked on a really uneven surface outside their garage which pushed the driver side wheel into the arch and highlighted where the tyre was making contact - this screw:
So - that screw had to go! The body panel and arch liner are secured by several other fixings - so I wouldn’t miss it.
You can see where the screw (passenger side pictured) had become shiny from the contact.
Around the same time, I was seriously considering shaving a few mm off the back of the wheels, following a suggestion from a fellow RS246 member at the Simply Audi show. I didn’t know this was “a thing” - but apparently a slight change in offset is possible as long as their is enough material on the inside hub of the wheel. I asked Camspec to help me find an engineering Shop to do the work, when they mentioned maybe I just remove the 3mm shims first. The what???
I had no idea these 3mm spacers had been fitted! They’d been supplied with the wheels, and the garage had thrown them on. My theory is that they would be needed out back on a car without ceramics (I needed 11mm rear).
Sure enough, if you look really carefully they’re there! Tuningwerkes hadn’t noticed them either, as there is a slight recess in the disc.
These had to go! Still plenty of caliper clearance
With these gone, the rubbing was almost gone - certainly a hell of a lot better.
I figured if I could just get this tab pushed back a couple of mm I’d be rubbing free:
So I contacted a mobile arch rolling company called Arch Enemy, and asked them to come out, after checking they could roll aluminium.
Well, it turns out, that panel is actually plastic! Whoops.
Only one thing for it, more chopping! The chap from arch enemy got to work with a hot Stanley knife and grinder! Image
After all that rather daunting chopping of my new R8 plastics - I’m now rubbing free!!!
I’m free to drive it properly again, and it looks spot on IMO.
2007 RS4 B7 Avant
Re: Faisal’s R8
Post by chunky79 » Sun May 20, 2018 4:27 am
That looks superb :rocker: Changing wheels can be such a ball ache sometimes.
I had a guy come out from Arch enemy for my RS6, he was useless!
Covkiller
Re: Faisal’s R8
Post by Covkiller » Sun May 20, 2018 9:51 am
This is a case in point for changing to different alloys and the problems encountered. A great write up with practical solutions to the problems. Very well done it's on song once more and looks fab :thumbs:
Re: Faisal’s R8
Post by Ian_C » Sun May 20, 2018 11:29 am
Great write up! I still think you are completely mad though! :jump:
Re: Faisal’s R8
Post by Ian_C » Sun May 20, 2018 11:31 am
Ian_C wrote:
Mon Mar 26, 2018 11:16 am
bam_bam wrote:
Mon Mar 26, 2018 10:50 am
Ian_C wrote:
Mon Mar 26, 2018 10:35 am
Time for a new avatar pic Bam - Photobucket error displaying for yours now
Cannae be arsed. I hate Cumbucket, they're the great ruiner of forums, I hope they all get bum cancer.
Bring your owl one back! Or you dancing like you just don't care.
YES YES :rocker:
FaisalJ
Re: Faisal’s R8
Post by FaisalJ » Mon May 21, 2018 9:20 am
Ian_C wrote:Great write up! I still think you are completely mad though! :jump:
That’s probably a fair assessment.
You know what’s really mad? I started eyeing up Teslas last week, for family duties. Drove the B7 over the weekend after not driving for a couple of weeks and talked some sense into myself!
2007 RS4 B7 Avant
Eddie555
Re: Faisal’s R8
Post by Eddie555 » Mon May 21, 2018 11:34 am
I hope that talk involved slapping yourself in the face a few times. Lol
Current ride’s
Previous rides
FaisalJ
Re: Faisal’s R8
Post by FaisalJ » Mon Jun 18, 2018 9:38 pm
Got some pics through from Nick
2007 RS4 B7 Avant
daytonamart
Re: Faisal’s R8
Post by daytonamart » Mon Jun 18, 2018 9:48 pm
Wibble at those alloys. Looking well Faisal.
Great beading too.
Gone B7 RS4 Sprint Blue Avant
Gone B7 A4 Reflex Silver
Covkiller
Re: Faisal’s R8
Post by Covkiller » Fri Jun 22, 2018 12:59 pm
Bloody Hell fire what did he use to dissolve the rings?
Return to “Readers' Rides”
Users browsing this forum: No registered users and 5 guests
