Top arms
andyg72
Re: Top arms
Post by andyg72 » Wed Apr 29, 2015 8:41 pm
geordie jay wrote:Drc ? :thumbsdown:
[/quote]
DRC all sorted :biggrin3: so I know it aint that[/quote]
Good good :)
theperm
Re: Top arms
Post by theperm » Sun May 17, 2015 6:50 pm
My indy VAG specialist recommended I get Lemforder or OEM arms, as he said Lemforder make them for Audi anyhow... saw the price eurocarparts do these arms posted on here, I dont know if anyone else has noticed but when you put in the vehicle details it actually list two separate sets, an expensive set which is close to Audi price at £99.54 for front £93.24 for rear and the cheaper ones at 43.48 (FU rear) £59.86 (FU Front).
Does anyone know what is the difference between these?
So i put in my old B6 TDI reg for a laugh and the same cheaper lemforder arms come up but the more expensive ones don't. So im guessing here that the cheaper one are standard b6/b7 arms and the more expensive ones are RS4 spec arms. I am going to see if i can ask Lemforder, i doubt eurocarparts would have an idea, but they will probably give a canned stronger or better response, which might not actually be far from the truth. I'm speculating that the bushs are slightly different spec on the RS4 to standard b7 and due to limited production less arms are sold they command the higher price. Thoughts anyone ?
theperm
Re: Top arms
Post by theperm » Mon May 18, 2015 4:13 pm
So spoke to my local Euro Car parts about this dilemma. When they looked up the system, one system specifies both arms but the "other" system which they seemed to regard as "the bible" only specified the expensive arms. She categorically stated it only lists the expensive ones for our cars, probably as its a direct Lemforder reference. So pretty much whats happening is all those who are buying the cheap arms from Eurocarparts are getting the wrong ones. I complained that the web site is then misleading but she refused to comment saying they had nothing to do with it, suggested I contact customer services and make the complaint to them. I've heard that before, the web site operates like a self contained branch all to itself.
toyneg
Re: Top arms
Post by toyneg » Mon May 18, 2015 4:43 pm
geordie jay wrote:I was reversing onto drive the other day.turned steering wheel full lock while backing onto drive and I heard a noise that could only be described as someone that had knocked once on bottom of car with a toffee hammer?same again happened day after and just once again.took it to my mate whos a mechanic for a quick look and he couldn't feel any play in bushes but after reading this post I think it could be the start of it.what you think fellas
am having exactly the same symptoms as you Jay, mine is going in tomorrow for some investigation
Re: Top arms
Post by MikeFish » Mon May 18, 2015 5:14 pm
The adjustable arms got both A4s and RS4s so they are probably the same physical size and shape which would suggest the difference may be the bushes as you suggested.
SamRs4
Re: Top arms
Post by SamRs4 » Mon May 18, 2015 7:38 pm
MikeFish wrote:£370 plus fitting:
http://www.awesomegti.com/034motorsport ... audi-a4-b7
If you are forking out for new top arms anyway they are about the same price as OEM ones without discount. Fitting will cost you the same. If I'd had known i needed some at the time,it would have cost me barely any difference to the OEM one I had fitted. Now it's gonna cost me £500+
Hello Mike I've been keeping an eye on this topic from the start as I'm soon to have kW adjustable spring fitted and am a bit confused as to the need to have adjustable top arms fitted the garage has told me there not needed if you lower within reason and don't go mad and do a wheel alignment when done but some of you have said this makes no difference and will still get wear on the inerside of front tyres so if I'm having work done on springs shall I get them done at the same time so don't have to pay for labor twice and how much i should lower by on front & back and I've got 10m spacers all round?
Harris.
Re: Top arms
Post by Harris. » Mon May 18, 2015 8:21 pm
theperm wrote:So spoke to my local Euro Car parts about this dilemma. When they looked up the system, one system specifies both arms but the "other" system which they seemed to regard as "the bible" only specified the expensive arms. She categorically stated it only lists the expensive ones for our cars, probably as its a direct Lemforder reference. So pretty much whats happening is all those who are buying the cheap arms from Eurocarparts are getting the wrong ones. I complained that the web site is then misleading but she refused to comment saying they had nothing to do with it, suggested I contact customer services and make the complaint to them. I've heard that before, the web site operates like a self contained branch all to itself.
Same as me last week , there different for the RS4 so £360 for all 4 . the ones on the web site are the cheap ones
SamRs4
Re: Top arms
Post by SamRs4 » Mon May 18, 2015 8:33 pm
Hello Harris how much did you lower it by on each axel and what did you pay?
DaytonaRs4
Re: Top arms
Post by DaytonaRs4 » Mon May 18, 2015 9:27 pm
Try jason at allgermancarparts. I got full meyle HD set from him a while back and prices were great. 5 year waranty on them. He does lemforder too (audi OEM but with audi stamp buffed off)
2013 RS5 Phantom Black, MRC Stage 2 and TCU, Bilstein B16 IRC, 034 Arms, H&R ARB's, Milltek non res, ITG, 20” Ispiri FFR6 / PS4s, AP Radical 6 pot brakes / 390mm floaters, Pagid RSL1, JL Audio, EMtuning headlight build, Gtechniq ceramic and Llumar PPF
Gone: Daytona B7 RS4 saloon
TonyHayers
Re: Top arms
Post by TonyHayers » Tue May 19, 2015 12:02 pm
I can heartily recommend speaking to allgermanparts. Both Jason and Matt were very knowledgeable and helpful.
06 Phantom Black Saloon:
^ GONE :cry:
theperm
Re: Top arms
Post by theperm » Tue May 19, 2015 1:49 pm
Just ordered set of Meyle HD top arms from AllGermanParts, price hard to beat and if they do as good a job as OEM. Top service from Mat. Folks Just be careful with those "cheaper" lemforder arms from Eurocarparts. They might no last as long as you hope.
toyneg
Re: Top arms
Post by toyneg » Tue May 19, 2015 4:38 pm
so the car has been up on the ramp today and there are no visible signs of anything wrong and the car just wont replicate the noise whilst there, so i will just see how it goes
jonnaz
Re: Top arms
Post by jonnaz » Tue May 19, 2015 5:50 pm
I also have this issue, when coming off a speed bump too quick or on full lock pulling onto the drive up a lowered kerb. as you say feels like someone has tapped the bottom of the car with a hammer.
I have had the car on an MOT ramp and used the shaker plates to try and replicate the fault nothing everything looks and feels good. I changed the (back) Front bottom suspension arms as the bushes had seen better days but the knock is still there. my feeling is it must be some Knackered bush or ball Joint.
geordie jay
Re: Top arms
Post by geordie jay » Tue May 19, 2015 10:51 pm
I have exact same issue jonnaz i assumed it was a knackered ball joint so was just gunna wait and see what mot throws up in a couple of months..but mine only happens the odd time when going up kerb onto drive when i got it on full lock
Harris.
Re: Top arms
Post by Harris. » Tue May 19, 2015 11:10 pm
Ive not picked them up yet mate , the bush don't worry me as ive got the power flex bush to fit so the standard ones will be cut out . the knocking people mention ,id say its front lower arm and rear arm bushes as these are under a lot of stress . Engine weight etc .im also going to power flex these . fit and forget with lifetime warranty
The top arms will only need changing if the steering wonders and don't feel tight .
Users browsing this forum: No registered users and 322 guests
