It measures wheel hp (which came out at 258), then I *think* they measure coasting deceleration to calculate drivetrain losses to then arrive at a flywheel figure. I'll read up and try an Arthur testsakimano wrote:Kudos for trying. I'd have happily paypal'd you a tenner should you do it again.
Also, the dyno dynamics... Does that measure wheel horsepower or crank horsepower? If it's crank you should do an Arthur test (official name) so we can see if it's really that dire (-80hp) or if the car just didn't like the dyno.
I can tell you that those crank numbers are like a stock b7 s4 and to cover 5000 rpms in third would take the s4 about 10 seconds whereas it takes the rs4 a little over 8
TerraClean RS4 test (FAIL FAIL FAIL)
- TonyHayers
- 5th Gear
Re: TerraClean RS4 test (FAIL FAIL FAIL)
06 Phantom Black Saloon:
^ GONE
^ GONE
Gotcha.TonyHayers wrote:It measures wheel hp (which came out at 258), then I *think* they measure coasting deceleration to calculate drivetrain losses to then arrive at a flywheel figure. I'll read up and try an Arthur testsakimano wrote:Kudos for trying. I'd have happily paypal'd you a tenner should you do it again.
Just a WOT rip through third gear on a flat road with the on board DIS stopwatch running and video the speedo and tacho so we can see how long it takes for you to go from 3000-8000 rpm.
comme ca
https://www.youtube.com/watch?v=15lcm98gSdM
yes mate not far from the centreTonyHayers wrote:Yeah, sure, are you near Leeds?STURS4 wrote: The guy who owned my car before me had a dyno test before having the heads removed and cleaned by hand.it ran 355hp before the clean then 405hp after.this is my second RS4 and its MUCH faster than the first,can really tell the difference.
when you get your x-pipe done dont suppose i could have a listen to it could i?thinking of doing it but im unsure if il like the sound or not.
- TonyHayers
- 5th Gear
Nice one. Car's in today for it..
http://forum.rs246.com/viewtopic.php?f=35&t=101637
I'll PM you when I've got it back. You don't have VCDS by any chance do you?
^ GONE
^ GONE
Users browsing this forum: No registered users and 195 guests
