Rolling Road Day @ AmD Essex
Firestarter
Re: Rolling Road Day @ AmD Essex
Post by Firestarter » Fri Oct 18, 2013 8:57 am
Morning all
FINAL list for Sunday. Door is closed now as the spreadsheet has been sent to Ben @ AmD earlier this morning. Dan I moved you up a couple of places as we still have 3 TBCs so put them to the bottom and I will place them on the day as appropriate. :bigblink:
No FORUM NAME NAME CAR TYPE
1 Ir8v10 Dave R8V10
2 Tellm Terry B7 RS4 Avant
3 Gavla Gavin B7 RS4 Saloon
4 Fatneck Aidrien C6 RS6 Avant
5 Toyneg Graham B7 RS4 Saloon
6 Scaghead Jay B7 RS4 Saloon
7 Noyjattat Gaz B7 RS4 Saloon
8 andy Andy C6 RS6 Avant
9 DaveM Dave B7 RS4 Avant
10 Surrey Sam Sam B7 RS4 Avant
11 Spikeyboy101 David B7 RS4 Avant
12 Graeme4130 Graeme B8 RS4 Avant
13 Sync24 Kev B7 RS4 Avant
14 Stairs Alistair B7 RS4 Avant
15 Stealthy Saf B7 RS4 Saloon
16 Silas Silas B7 RS4 Avant
17 GroundControl Sam B7 RS4 Avant
18 Ginors4 Gino B7 RS4 Avant
19 MikeFish Mike B7 RS4 Saloon
20 Sutts Ian B7 RS4 Avant
21 Jaheenormous Jahee B7 RS4 Saloon
22 coupe_bloke Ben B7 RS4 Avant
23 F11KED David B7 RS4 Saloon
24 Firestarter Louie B7 RS4 Saloon
25 Nainoo Ahmed B7 RS4 Saloon
26 S4WON Dan B7 RS4 Avant
__________________________________________________________
27 saintS400 Mark B8 S4 Saloon (NO DYNO RUN TIME SPECIFIED)
28 Scaff657 Marc B7 RS4 Saloon (NO DYNO RUN TIME SPECIFIED)
29 Red_Rocket Ahmed B7 RS4 Avant (NO DYNO RUN TIME SPECIFIED)
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT :-)
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre :-)
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
spikeyboy101
Post by spikeyboy101 » Fri Oct 18, 2013 2:07 pm
Thanks.
What time does it all kick off ? any idea how long each run takes ? may give the later people an idea of when their run will be taking place.
PhilT
RS246.com
Post by PhilT » Fri Oct 18, 2013 2:33 pm
Trying to sort out getting a banner to the event... Anyone passing through South Yorkshire or going to Unit 20 before this?
Firestarter
Post by Firestarter » Fri Oct 18, 2013 2:41 pm
PhilT wrote:Trying to sort out getting a banner to the event... Anyone passing through South Yorkshire or going to Unit 20 before this?
Hi Phil
I think the furthest north that one of the guys is travelling is from Leicestershire so unfortunately not. :(
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Firestarter
Post by Firestarter » Fri Oct 18, 2013 2:45 pm
spikeyboy101 wrote:Thanks.
Hi David,
The event starts at 9am prompt. I've asked Ben how long each run takes, but I reckon 4 cars an hour (just my guess)
I'll confirm once Ben comes back to me mate :biggrin3:
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Firestarter
Post by Firestarter » Fri Oct 18, 2013 2:51 pm
All
The schedule for the Dyno runs is not set. However I have asked Ben a few questions which I have shown below with his answers in bold
1.Is there anywhere we can plant a few GoPro cams to film each car on the dyno?
If you have tripods for them there will be, there isn’t anywhere you could mount them without sticking them to the wall.
2.Its looking like it gonna be pissing down, so assuming that each car can be run on the dyno if wet?
Not a problem to run the cars if its wet.
3.Is there an area where the guys can shelter throughout the day if the weather is pants?
People will be allowed in the workshop to watch the cars on the dyno
This point is for attention of Dave
With the R8 V10, for this to run correctly on the dyno we have to run it in RWD only, which means removing the prob. We can do this but it means it won’t be able to run first.
Im not going to alter the schedule and also I have now made up and numbered the name badges, so Dave we can discuss this when on site and get your run done ASAP.
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Noyjatat
Post by Noyjatat » Fri Oct 18, 2013 2:56 pm
Great job getting this all sorted Louie. Mrs T must be proud!
Post by bam_bam » Fri Oct 18, 2013 3:24 pm
A few tips:
- Be careful of stones working loose from the tyres as they tend to bounce around a workshop at high speed
- If you're gunna be there all day, wear some muffs *snigger*
- Budget 20mins per car, it looks like it'll be a 10+ hour day for you lot
- Ensure everyone is prepared to run well before their place is called. This includes having their tyre pressures set and engines warmed up. You'd be surprised how many times you'll be calling out names only to find they've gone for a drive to warm up the engine and causing dyno downtime. I suggest enforcing a punishment for being tardy, a round of "dead-arms/legs" will usually do it.
- If someone's car has a fault don't let this cause an overrun on their dyno slot, just get it off the rollers and shuffle it, you'll be there all day otherwise.
- Don't be afraid to sit in the boot if there are traction issues, you only live once
- Ensure no one is running winter tyres, they're soft, they'll heat up and stink out the workshop
- Don't forget to tip the stripper, she'll take care of you
Timster
Post by Timster » Fri Oct 18, 2013 3:51 pm
bam_bam wrote:A few tips:
- Get Norris McWhirter down there to see if it’s “a record number of dyno’d cars for one day”.
(although he’ll probably give you a completely irrelevant answer involving the number of vertebrae in a giraffes neck. Nervously smile and accept the answer anyway)
I think it’s 7, like us btw.
Firestarter
Post by Firestarter » Fri Oct 18, 2013 4:44 pm
Noyjatat wrote:Great job getting this all sorted Louie. Mrs T must be proud!
Thanks Bud.....I've enjoyed doing it and will be great to have a load of like minded chaps together.
There is no longer a Mrs T Gaz........Thank the lord :biggrin3: There is however a lady on the my radar who I've been seeing for a couple of months :bigblink:
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Firestarter
Post by Firestarter » Fri Oct 18, 2013 4:49 pm
Cheers Bam....some very good pointers there buddy and appreciate you posting this. :thumb:
Ben said that they should get through 4-6 cars an hour if running smoothly, so if an average is taken the event should go on till around 3pmish, but that also depends on how many chaps want a go on the stripper :jump:
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Post by MikeFish » Fri Oct 18, 2013 4:59 pm
Hi Phil
Yep, it's quite a way out for me. If anybody happens to be going through South Yorkshire and down the M1 tomorrow it should be easy enough to do a drop off then I can bring down on sunday.
scaghead
Post by scaghead » Fri Oct 18, 2013 5:15 pm
Louie,weather reports keep changing for Sunday,at the moment cloudy/sunny 17 degrees we might hit some heavy showers though..but that may change again...
Graeme4130
Post by Graeme4130 » Fri Oct 18, 2013 5:37 pm
She's not a stripper is she, as the event still needs one of those :))
Seriously though, thanks for organising this
I organise events for a living, so I know just how time consuming these sort of things are
sync24
Post by sync24 » Fri Oct 18, 2013 7:40 pm
gentle reminder can someone pl bring Vagcom plus cable if poss
Users browsing this forum: No registered users and 92 guests
