DIY, Front brake pads and disc replacement
sonny
Re: DIY, Front brake pads and disc replacement
Post by sonny » Mon Apr 15, 2013 6:50 pm
Ahh yes they can be a nightmare to get out. Hope you get it sorted.
Tile Diver
Post by Tile Diver » Mon Apr 15, 2013 7:47 pm
esp_mm-270 wrote:Well, had a go friday and its booked in for weds. Failed at the first hurdle, n/s/f upper pad pin was friction welded or jammed in. Looks like it was a problem last time the pads were done as the point of the pin was flattened (no copper slip in there either) :( Spose I could've purchased a dremel and cut it out but I had gotten the hump by then :FIREdevil:
Oh well, will be done soon and she'll be back in business :kissmyrings: (Meaning love my Audi)
M
Man, I also took on the job of changing front discs and pads, and like yours the pad retaining pins were a nightmare, I had 3 that just wouldn't budge!!!
I ended up nipping the brake hoses, removing the calipers on both sides, taking them down to the local garage where they had to apply some heat and a lot of hammering, finally they came out!!
So back up to the house it was, bang the calipers back on the car, bleed the brakes and Hey Presto all sorted!!!!
I'll do anything not to give the stealers money, and I made sure all the pins were well copper slipped. I'm actually that paranoid about having the pins seizing again I actually remove the pins now and then and copper slip them again!!! :bigblink:
Black Optics / Ti Pack
SS Suspension +
Sunroof
H&R Hubcentric Spacers
Milltek Res / Valved Cat Back
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
If in doubt.. Power out!!
esp_mm-270
Post by esp_mm-270 » Mon Apr 15, 2013 8:41 pm
^^^^^^^ Thats not a bad idea :)
Tile Diver
Post by Tile Diver » Mon Apr 15, 2013 8:56 pm
esp_mm-270 wrote:^^^^^^^ Thats not a bad idea :)
:beerchug:
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
Spaceman_RS4
Post by Spaceman_RS4 » Tue Apr 16, 2013 3:20 pm
I had a couple stuck pins when I done mine. What I did was leave them as they were and simply remove the pads from the inside. Save buggering a about and damaging anything.
Ordered b9 S4 Avant ibis white
Panther black 8V RS3
Misano Red B7 RS4 Saloon
Yanos
Post by Yanos » Tue Jul 09, 2013 7:31 pm
Thanks for posting this Sonny, I am going to take this on soon and this is a great help!
RS4 B7 Misano Red Saloon / Black Optics / Revolution - Pipercross Carbon air intake / Carbon Clean / Black Rings / Lepsons Black Chrome Alloys
PJC
Post by PJC » Tue Jul 09, 2013 7:57 pm
Sonny's good too he did mine for me.
R1RS4
Post by R1RS4 » Mon Oct 07, 2013 8:15 pm
Hi There,
Just a little tip I have used over the years when changing brake pads,
When the brake fluid level rises as you open the calliper pots I use a small ( empty )plastic bottle say around 250ml with nozzle and what you do is squeeze all of the air from the bottle stick the nozzle into the brake fluid keeping the nozzle submerged and let the bottle suck out the excess! wham no mess, then providing the bottle is (very clean) you can re - use the fluid if needed...when the level settles
Richard
RS4 B7 Avant,2007
Users browsing this forum: Google [Bot] and 367 guests
