13,000 miles warped disks - yes another one....
klauster
Post by klauster » Sun Sep 12, 2010 7:38 pm
I'm on my 3rd set of discs, would say I am doing exactly what adsgreen has suggested above and it has made a difference as my current set are lasting well
ArthurPE
Post by ArthurPE » Sun Sep 12, 2010 8:14 pm
klauster wrote:I'm on my 3rd set of discs, would say I am doing exactly what adsgreen has suggested above and it has made a difference as my current set are lasting well
how many miles per each set?
how many on this set?
what pads?
klauster
Post by klauster » Mon Sep 13, 2010 12:44 pm
OEM pads, last set of disks didnt even last 5000 miles, this set have been on for well over 7k... I managed to get good will up to now, there is deffo something wrong the design.
Dom81
Post by Dom81 » Mon Sep 13, 2010 12:51 pm
klauster wrote:last set of disks didnt even last 5000 miles
:shock:
2007 Daytona RS4 Avant
PetrolDave
Post by PetrolDave » Mon Sep 13, 2010 1:02 pm
klauster wrote:OEM pads, last set of disks didnt even last 5000 miles, this set have been on for well over 7k... I managed to get good will up to now, there is deffo something wrong the design.
My first set of OE pads lasted 33,000 miles, but I've been told to expect the current set to "only" last about 20,000 miles and to need new disks then.
That would make approx. 50,000 miles from a set of OE discs and an average of approx. 25,000 miles from a set of OE pads - doesn't sound like there's anything wrong with the design to me?
bye bye
Post by bye bye » Mon Sep 13, 2010 1:07 pm
Looks like you have been very lucky!
RS6chris!
Post by RS6chris! » Mon Sep 13, 2010 1:09 pm
All i can say is must be some heavy brakers around or a lot of track days?? I,m on 28k now on original discs (they are mint) second set of front pads with plenty left on them?
However i do engine brake alot and forward think in traffic to avoid wear and tear. I also look after discs etc by regulaly drilling out debris from holes...
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
ArthurPE
Post by ArthurPE » Mon Sep 13, 2010 1:25 pm
PetrolDave wrote:My first set of OE pads lasted 33,000 miles, but I've been told to expect the current set to "only" last about 20,000 miles and to need new disks then.
I'm pretty much on pace for that
37k miles on the rotors (just mic'ed them at ~50%), although wear will accelerate as they get thinner...so 50k is a good guess
1st pads ~25k
2nd got ~12 on them so far
PetrolDave
Post by PetrolDave » Mon Sep 13, 2010 2:08 pm
hody7869 wrote:Looks like you have been very lucky!
No, it's all down to driving technique.
I try to read the road ahead so I rarely use heavy braking, usually only when I misread the road (glancing at the map on the RNS-E screen can be very helpful) or something unexpected happens like another driver's "strange" behaviour.
Being in the right gear and being at the right speed for the road while keeping your brakes "in reserve" is how I was taught to drive, and when descending long hills or Alpine passes it makes sure you still have brakes at the bottom!
Good driving is about smoothness and anticipation, not about neck jerking acceleration and braking, your car is more stable and more planted and you get from A to B quicker and less stressed. Look at the Top Gear fast laps - the smoother they look, the quicker they are.
klauster
Post by klauster » Mon Sep 13, 2010 2:15 pm
Well having driven a few cars, this is the first car that I have had so many issues with brakes, and I don't think i'm driving any different at all.... Audi assumed that there was a manufacturing issue with my last set, hence the vibration after a short period of time, remember that it could have been that they were poorly installed in the first place....
The bottom line is, I doubt any of the brakes issues RS4 drivers are having is down to driving style
adsgreen
Post by adsgreen » Mon Sep 13, 2010 2:40 pm
The problem is the sheer size of the discs - both the RS4 (and my old VXR8) have larger than avereage discs. This gives them a huge leverage advantage over smaller ones so it only take a fraction of the contact force for them to start working. I'm convinced after my previous investigations that for day to day driving it's too easy to be to light on them and start down the road to disc wobble. Smaller disc sizes are not as prone as they need more effort to use them.
It's incredibly hard to warp modern discs through over using them - The design and construction techniques are so good that you'll be killing the brake fluid before the discs will start to overheat and fail.
I've done endurance racing on a set of OEM discs on another marque and they were fine.
That being said, you can wreck discs easily from installing them in the wrong way.
P_G
Post by P_G » Mon Sep 13, 2010 2:52 pm
RS4414. wrote:All i can say is must be some heavy brakers around or a lot of track days?? I,m on 28k now on original discs (they are mint) second set of front pads with plenty left on them?
I'm not a heavy breaker, don't track and use engine breaking but I'm on my 4th set of front and 3rd rears, albeirt I skim mine now rather then replace for new. There is a lot to be said about the amount of brake dust that clogs the holes and generates hot spots in the discs causing high spots. Like said previously now I have EBC yellowstuffs on and the dust produced by them is less than OEM Pagid, I do not have near as many issues. Current discs ahve been on 12k miles and good. Mind some people replace fronts only to find it is the rears that have issues and if left to long I believe that the the vibration through the car from the rears will affect the fronts too. Did on mine.
The design I maintain is not the best and designed to a budget. Look at the size of the cross drilled holes on the 385mm Brembo discs, holes are at least 1mm wider on them.
bye bye
Post by bye bye » Mon Sep 13, 2010 5:32 pm
RUBBISH.
Well, I had a Boxster S previously, drove like a loon and got 45k miles from the disks and 30k on the first set of pads.
13K from a set of high performance disks is not down to driving style. I drive in a very similar way to you..(although maybe not quite as well as you) ..it's my daily driver and I need to look after it.
I've driven 13k miles in 12 months which I do not think is excessive.
Your post was a tad assumptive :!:
bye bye
Post by bye bye » Mon Sep 13, 2010 5:33 pm
AGREED :D
adsgreen
Post by adsgreen » Mon Sep 13, 2010 5:37 pm
The size of the holes won't cause this problem. Like it or not, Driving style can be a factor.
Seriously worth evaluating if you are being to easy on the brakes. Use them a little harder (not saying emergency stop everywhere) and it'll have marginal effect on the wear rate but could prevent such early disc failure.
Sorry - sounding like a scratched record now. It's just I spent a huge among of time researching this. Even had my discs sent off to be investigated and it was uneven pad material transfer causing the misalignment and not a warped disc.
Users browsing this forum: Zyox and 378 guests
